My oil cooler install |
hars914 |
Mar 29 2004, 10:10 AM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
Here is my oil cooler install on my 71. A little different from the norm and works
great. The cooler is a Setrab with (2) 6" fans. I fabricated the shroud from 6" metal elbows and bent plate. I have -12 lines into a Mocal Thermostat then run the lines in the wheelwell and behind the rockers. Attached image(s) |
ArtechnikA |
Mar 29 2004, 10:14 AM
just curious why you run the thermostat close to the cooler rather than close to the engine.
Eric Taylor |
Mar 29 2004, 10:15 AM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Very Nice! (IMG:style_emoticons/default/smilie_pokal.gif) ! What engine do you have in there?
eric |
machina |
Mar 29 2004, 10:17 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
looks great, any pics of the front intake and the underside outlet?
been thinking about oil cooler for a while. dr |
RON S. |
Mar 29 2004, 11:08 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
Looks Great,really professional looking setup.
But how hot does the engine oil temp go on the gage,before the thermostat opens. Ron |
SLITS |
Mar 29 2004, 11:16 AM
Do the fans suck or blow ( which way do you exit the hot air)?
Nice pro install. |
StratPlayer |
Mar 29 2004, 11:43 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Like to hear some pros and cons of where his thermostat is located.......
ArtechnikA |
Mar 29 2004, 11:50 AM
QUOTE(StratPlayer @ Mar 29 2004, 09:43 AM) Like to hear some pros and cons of where his thermostat is located....... puts a bit of strain on the oil pump (and sucks some power) to pump cold oil all the way to the front, only to have it bypassed back again. and hot oil is a lot easier to pump. i can't think why you'd want a thermostat at the cooler end - which is why i asked - i am hoping to learn something... |
hars914 |
I have a 2.4L 4cyl. motor in the car so I need the cooler. The fans suck air from
the cooler which also draws from the opening in the valance then out thru the opening in the trunk floor. I do not think it matters where you mount the thermostat.I have seen them away and also near the cooler.I have a switch on the dash now for the fans. I turn them on if the temp goes up in traffic. I plan on installing a fan thermostat switch in one of the lines if I think it needs it. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:56 PM |
