Decelerates then dies..., Having running issues |
Frost |
Mar 23 2010, 02:45 PM
Frost Group: Members Posts: 75 Joined: 9-May 08 From: Houston,TX Member No.: 9,035 Region Association: Southwest Region |
Need some help, ive been doing my research and still no results. At first the car didn't start so i replaced the fuel pump, regulator, relay and fixed the ground then it started right up like a champ. When i went to test drive it i could get it to 3rd then it wouldn't want to go past 3rd and start decelerating with no control. I replaced the coil, since the friend i bought it from told me it was really old, trigger point, condensor, and head temp sensor. Went to test drive it and i could'nt even get out of first before it would start decelerating and die on me, I could drive it for a little bit after i turned the key off and the then start it but same issue after a minute. (IMG:style_emoticons/default/headbang.gif) Im narrowing it down to fuel pressure sensor, what do you guys think?
Kirmizi |
Mar 23 2010, 03:24 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Fuel filter? (IMG:style_emoticons/default/confused24.gif)
Mike |
tod914 |
Mar 23 2010, 03:37 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Did you inspect inside the gas tank? Sock clogged?
Zardozz |
Mar 23 2010, 04:06 PM
Member Group: Members Posts: 107 Joined: 31-March 08 From: Orange County, CA Member No.: 8,874 Region Association: None |
Sounds like a fuel issue or lack there of. I got $20 on the filter. Who's taking the sock?
flat4tom |
Mar 23 2010, 05:38 PM
Member Group: Members Posts: 51 Joined: 6-January 10 From: Shingletown CA Member No.: 11,207 Region Association: Northern California |
Need some help, ive been doing my research and still no results. At first the car didn't start so i replaced the fuel pump, regulator, relay and fixed the ground then it started right up like a champ. When i went to test drive it i could get it to 3rd then it wouldn't want to go past 3rd and start decelerating with no control. I replaced the coil, since the friend i bought it from told me it was really old, trigger point, condensor, and head temp sensor. Went to test drive it and i could'nt even get out of first before it would start decelerating and die on me, I could drive it for a little bit after i turned the key off and the then start it but same issue after a minute. (IMG:style_emoticons/default/headbang.gif) Im narrowing it down to fuel pressure sensor, what do you guys think? Did you pull the fuel tank and replace the fuel lines under the tank? If so, upon re-installation, one of the fuel lines might have kinked. I just went though this but my car would choke out and decelerate any time I made a turn. The fuel pump was much louder as well while this was happening. Even if not, you might want to take a look at them to be sure they're not kinked 'cause it sounds like one might be. Just my .02. Tom |
markb |
Mar 23 2010, 06:54 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Sounds like a fuel issue or lack there of. I got $20 on the filter. (IMG:style_emoticons/default/agree.gif) |
Frost |
Mar 23 2010, 08:57 PM
I replaced the filter and still same problem. I hooked up a pressure gauge and got 25psi then when you rev it the psi would go down and down and down to almost 0, after letting it idle for a little bit it would start to go back up. I'm leaning to a faulty fuel pump even though that was the first thing i replaced.
tod914 |
Mar 24 2010, 07:57 AM
Look inside your gas tank and see what's going on. Talking off the fuel filler is quick and easy.
Lo-Fi Version | Time is now: 8th June 2024 - 03:15 AM |
