> Battery Tray Options, What methods of install? Bolt, weld, rivit nuts, etc.....
Mr.242
post Mar 24 2010, 06:45 PM
May your glass be smaller so it's always FULL!
So here is my current state of my battery tray. I have removed the motor and I'm cleaning the bay to have it painted; hopefully soon!
I have agreed to purchase a battery tray and support, and I see this new install and I wonder what options I have. Here's GA1142's recent post:
I was wondering what people have done to mount their tray. I was told of by my body man of the option of using "rivet nuts" so I can unbolt the tray and support to clean up under the tray. Looking for some .02 cents on the topic. It's being done on a real SIX, but not for concours status. For DE, AutoX, and beat my bro!
Thanks.....ping away with ideas.
Replies(1 - 14)
r_towle
post Mar 24 2010, 07:20 PM
Custom Member
If the lower support is seam welded, and you bolt the top tray to both the inner fender and the lower support, I would certainly do it with the rivnuts.
I weld them in, but next time I get my engine out, I plan on doing the same type of removable install so I can clean that area better.
Rich
sww914
post Mar 24 2010, 07:28 PM
You must be sure that the tray is flat where the battery sits. If the battery is riding on bolt heads they will wear through the bottom of the battery and make an acidic mess.
agentblr
post Mar 24 2010, 07:33 PM
Do the right thing.....mount your battery in the rear trunk. Where they should have put it in the first place!
qa1142
post Mar 24 2010, 07:54 PM
Whiplash
Weld it in right. (IMG:style_emoticons/default/welder.gif)
I drilled holes where each spot weld should have been and filled it with my mig.
With engine out, I had Brad clean up that work and make it look good
Do it right
Eric_Shea
post Mar 24 2010, 09:12 PM
PMB Performance
Do the right thing and weld it in where it's suppose to be... it's an original -6. (IMG:style_emoticons/default/slap.gif)
McMark
post Mar 24 2010, 09:33 PM
914 Freak!
Weld it where it's supposed to go. They battery trays rusted out because of rain. Is your car going to live out in the rain?
--AND--
Why would anyone sacrifice trunk space, when the battery's got a perfectly good home in the engine bay.
--AND--
I wouldn't trust a riv nut to hold a heavy battery being tossed around under spirited driving. You're just asking for that battery to jump loose and crack into a carb. Yikes!
--AND--
(IMG:style_emoticons/default/cool.gif)
jgara962
post Mar 24 2010, 09:47 PM
Yo, this is how I roll
I had to have McMark weld a new tray in for me. The old one was held with rivets and failed on the way to the WCR autox a few years ago. What a dissapointment not being able to run because of a poor fix. Welding it in is the only way to go.
jmill
Green Hornet
QUOTE(McMark @ Mar 24 2010, 09:33 PM) *
(IMG:style_emoticons/default/agree.gif) Riv nuts are far from structural. I only use them on access panels or other light weight stuff. In that area I wouldn't be surprised if they spin on you when you try to loosen the bolt. Ever try and drill out a spinning riv nut? BTDT. It blows.
post Mar 24 2010, 09:55 PM
Resident German
Mr.242
post Mar 24 2010, 10:37 PM
QUOTE(Eric_Shea @ Mar 24 2010, 08:12 PM) *
What the hell....I got a whack in the back of the head?? (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/blink.gif)
Even though I live in Seattle, it will not live in the rain.
Thanks for the input. Love the facts that come from other peeps trials and FAILS.
Will weld it in....... (IMG:style_emoticons/default/welder.gif)
Thanks everyone! I will keep you posted.....
Eric_Shea
post Mar 25 2010, 08:55 AM
PMB Performance
It was a love tap. (IMG:style_emoticons/default/biggrin.gif)
Now... (IMG:style_emoticons/default/alfred.gif)
jonferns
post Mar 25 2010, 09:31 AM
Weld it in, its permanent and you won't have worry about it falling off.
Here's mine, just painted the engine bay recently.
Root_Werks
post Mar 25 2010, 09:47 AM
Village Idiot
QUOTE(qa1142 @ Mar 24 2010, 06:54 PM) *
Do it right
It doesn't take much to hold the two pieces in place very strongly. Drill a couple of holes in the two pieces, then 'tac' or fill the holes when you weld them to the car.
Even 'tac' the tray to the support. The factory never bolted the two together. You have a six, keep it as original as possible.
The cleaning and prep will take the longest. The 'tac' welding will take minutes.
jt914-6
post Mar 25 2010, 11:45 AM
On your original six, keep it in the stock location and use an Optima or other totally sealed battery. No acid to spill or rain spreading acid.... (IMG:style_emoticons/default/welder.gif)
- Lo-Fi Version Time is now: 9th November 2026 - 10:44 AM
