Ignition switch going out, How the heck do you get it off? |
dan10101 |
Mar 27 2010, 06:05 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
So its been 5 years or so since I've actually taken one out, but my ignition switch is going out (odd to, The key will turn to the ON position, and it will turn to the starter position, but there is a dead spot in between making the ON position really small, and making it almost impossible to start the car...) So I need to get it out to see if I can fix it my hand or If I need to use my spare. Anyone have a HOW TO on how to get this thing out of the steering column? I have the column dropped and for the life of me cant figure it out.
thanks all! Andrew |
Kirmizi |
Mar 27 2010, 06:26 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
The electrical (switch) or the mechanical (tumbler) portion? Depending upon the year, the switch is held in place by a setscrew or small phillips head. IIRC the pre-75 cars tumblers will come out after turning the key to the "start" position".
Mike |
Andyrew |
Mar 27 2010, 06:32 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Actually the whole assembly. Figured it out though... Those four tiny screws at the front let you get to it.. Now I'm sourcing the electrical portion as I do t think I have a working spare. Oh hey pelican has them for $9!
Andyrew |
Mar 27 2010, 06:43 PM
14.15 out the door. I'll have it on Tues.
Cheapest part order I have ever had! (BTW, DAN10101 is my fathers account) Thanks guys! Andrew |
Kirmizi |
Mar 27 2010, 07:44 PM
Good luck with the new switch from Pelican.
I had more problems with the "new" replacement switch, than with the old, cracked one. Wound up ordering an OEM from Jonathan at GPR. Mike |
dr914@autoatlanta.com |
Mar 27 2010, 08:25 PM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
So its been 5 years or so since I've actually taken one out, but my ignition switch is going out (odd to, The key will turn to the ON position, and it will turn to the starter position, but there is a dead spot in between making the ON position really small, and making it almost impossible to start the car...) So I need to get it out to see if I can fix it my hand or If I need to use my spare. Anyone have a HOW TO on how to get this thing out of the steering column? I have the column dropped and for the life of me cant figure it out. thanks all! Andrew "Tech Tips 700" has an easy procedure. Please beware of inferior ignition switches! Cheap ones have too much play and will now allow the key to turn far enough to start the car!!!!!!!!!!! |
Andyrew |
Mar 27 2010, 08:39 PM
Hmm Odd, I guess i'll have to keep that in mind. George how much are your "Expensive" switches?
I'll let you know if I have any trouble. Pelican has always been my go to guys, the fact that its 1 day shipping to me is helpful as well or else I would buy from you guys. Andrew |
Lo-Fi Version | Time is now: 1st June 2024 - 06:28 AM |
