Koni insert into Koni Strut |
my928s4 |
Mar 28 2010, 04:26 PM
Member Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest |
These are Koni inserts 8641-1077, the struts are Koni 911 341 079 10 and there seems to be a mismatch as the inserts hang up before fully inserted. I did not try gently tapping in with a rubber mallet I figured they were supposed to drop right in?
The picture shows where the insert start to hang up. Thoughts? |
Eric_Shea |
Mar 28 2010, 05:13 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'd say those inerts are Koni's that are made for a Boge strut.
my928s4 |
Mar 28 2010, 06:05 PM
Richard Casto |
Mar 28 2010, 09:16 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Check out post #7 in this thread...
http://www.914world.com/bbs2/index.php?showtopic=70929 I believe you are trying to do what I describe in item #2 in that post. Which is to use a 914 Koni insert in a 911 Koni strut. As you have found out where the insert necks down is too far down and does not match up with where the strut necks down. So it almost, but not quite fits. For that strut, you need the 911 Koni insert (8641-1039 Sport). On post #11 of that thread I show a similar photo to yours, but you can see that the neck on the 911 Koni insert is much higher, so it fits. The valving between the 914 and 911 in slightly different. Maybe not enough for you to notice. You can always have Koni revalve the 911 insert to the spec of the 914 insert. |
my928s4 |
Mar 30 2010, 10:33 AM
Richard
Thanks for the link, your prior post sums it up pretty well. I ordered the 911 shocks from Jason with the gland nuts this morning. Will post the new 914 shocks in the classified for $200 (for the pair) which is what I paid for them. |
Richard Casto |
Mar 30 2010, 03:26 PM
Glad I could help. It's always great when you can give someone info that actually helps them out! (IMG:style_emoticons/default/smile.gif)
It's also good you saw the bit about the special gland nut. By default the inserts are packaged with a gland nut for the Boge strut (as this is the most common strut). So if you are using a Koni strut, you have to buy the Koni Strut specific gland nuts as the thread pattern, etc. is different between the Boge and Koni struts. |
veltror |
Mar 30 2010, 06:06 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
Does anybody have an email and full name for this Jason bloke? I have had no succes in sourcing these gland nuts in the Uk besides I am also missing the adjusting plastics screws and some other bits...
Ta... |
my928s4 |
Mar 30 2010, 06:46 PM
veltror |
Mar 31 2010, 02:58 AM
thank you Chris
Lo-Fi Version | Time is now: 11th June 2024 - 02:06 PM |
