e-brake combo gauge wiring, what do these wires do? |
dem |
Apr 4 2010, 01:41 PM
Rusty Member Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California |
I have a '73 914 converted to a 914-6, that previously had a 911 combo gauge (pressure/temp)
I'm cabling up a super cool Mark-quad-gauge, but am puzzled by the e-brake lamp. It has a lot more wires going into it than the other lamps. Anyone know what they are? One of the brown/white is the ebrake. Also the power lead is black/white/green, while the others are the normal red/white switched. If I was better at reading schematics I'm sure it would make perfect sense. My inclination is to just plug it in, but I thought I'd ask first. There's enough electrical weirdness with this car I'd rather understand things (radio powered off the clock, for example, is probably not correct!) Thanks. Dennis (IMG:http://www.914world.com/bbs2/uploads_offsite/www.haphazard.com-11334-1270410064.1.jpg) |
McMark |
Apr 4 2010, 02:01 PM
The ebrake light also functions as the brake master cylinder failure warning light. So if you see that flashing red light, either your e-brake is on, or your master cylinder has failed. So you have a +12v supply wire (which is your black/white/green), you have your brown/white w/ diode which goes to your parking brake (and safety belt warning light), and you have your brown/white which goes to your master cylinder.
So that all looks right, from what I can see. |
shoguneagle |
Apr 4 2010, 10:06 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
WHAT TIMING!!!! I am in the process of wiring 911 guages into my 914-6 and came across this thread. I had one extra wire (black/white/green) and could not find where it went. Prior I had changed my 1974 to a 1973 wiring harness. I saw this thread and the picture - everything came together.
The light socket I used was only two prong whereas I needed a two prong with an additional electrical connector on the diode side; also, led to the solving of my problems with the m/c brake warning system and the emergency brake warning light system. This is what I can a very good day - solving three problems with information someone made on a thread inquiry. Greatly appreciated and thank you! Steve Hurt |
Lo-Fi Version | Time is now: 6th June 2024 - 07:13 AM |
