Need suggestions for a throttle cable |
casey944 |
Apr 5 2010, 07:12 AM
Member Group: Members Posts: 139 Joined: 10-August 09 From: nova Member No.: 10,654 Region Association: MidAtlantic Region |
There was some info on the "other site", that i have completely given up on, regarding a throttle cable for 914s.
What do you recommend? OEM? Is there a better aftermarket solution? Thanks in advance. |
casey944 |
Apr 5 2010, 07:55 AM
http://www.zimsautotechnik.net/acatalog/Te...__914-4_70.html
found that one along with the standard 91442306702 Any insight? |
pcar916 |
Apr 5 2010, 07:57 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
dr914@autoatlanta.com |
Apr 5 2010, 08:53 AM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
stock works great just make sure that it is the original gimo and not that italian one that is made backwards. Also make sure that it is greased before installation, and we spray down the tube with a bit of wd40 before inserting the cable, Casey.
tat2dphreak |
Apr 5 2010, 09:16 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
get a Terry cable. they work great!
casey944 |
Apr 5 2010, 09:20 AM
Taking George's recommendation and I ordered a 700 tech tips book as well... Anyone know of a good diy that includes pictures?
Nie Zu Alt |
Apr 5 2010, 09:36 AM
Member Group: Members Posts: 173 Joined: 1-June 05 From: Centennial, CO Member No.: 4,184 Region Association: Rocky Mountains |
George,
What's the story on the Italian one "made backwards"? Just wondering so I'll know what to look out for in the future. Thanks |
casey944 |
Apr 5 2010, 09:51 AM
Anybody have an idea of how long it takes to install?
tat2dphreak |
Apr 5 2010, 10:04 AM
QUOTE Anybody have an idea of how long it takes to install? about 10 minutes if the car is already up where you can get to it... |
r_towle |
Apr 5 2010, 10:14 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
First off...Call George and have him put two cables on your order...
Put the spare one in the trunk...you will thank me someday within the next 5 years. Remove drivers side carpet. Remove plywood pedal board..it does come out, a few allen head bolts and it really does come out without breaking it....its just a bit of an odd puzzle... If you have a center console...remove it and put it on the passenger floor. Remove the cable end that attaches to the gas pedal on the pedal cluster. Pull out the broken end via the front. Disconnect the cable at the throttle body and feed it under the car. Pull it out of the tube. Slide new one in (greased and lubed) Hook it all back up. |
jt914-6 |
Apr 5 2010, 10:20 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
First off...Call George and have him put two cables on your order... Put the spare one in the trunk...you will thank me someday within the next 5 years. Remove drivers side carpet. Remove plywood pedal board..it does come out, a few allen head bolts and it really does come out without breaking it....its just a bit of an odd puzzle... If you have a center console...remove it and put it on the passenger floor. Remove the cable end that attaches to the gas pedal on the pedal cluster. Pull out the broken end via the front. Disconnect the cable at the throttle body and feed it under the car. Pull it out of the tube. Slide new one in (greased and lubed) Hook it all back up. (IMG:style_emoticons/default/agree.gif) The only thing to add is check and make sure you don't get it wrapped around the clutch cable when installing. Before putting the pedal board back in start it up and push in the clutch and see if it revs up any..... |
tat2dphreak |
Apr 5 2010, 10:25 AM
QUOTE First off...Call George and have him put two cables on your order... Put the spare one in the trunk...you will thank me someday within the next 5 years. (IMG:style_emoticons/default/agree.gif) totally! clutch cable too! FWIW, tho, when I put in the Terry cable, I did not remove the console or the carpet. yes it was a little tight, but it wasn't that bad.... I just pulled the carpet back a little to get the pedal board out. |
r_towle |
Apr 5 2010, 10:43 AM
QUOTE First off...Call George and have him put two cables on your order... Put the spare one in the trunk...you will thank me someday within the next 5 years. (IMG:style_emoticons/default/agree.gif) totally! clutch cable too! FWIW, tho, when I put in the Terry cable, I did not remove the console or the carpet. yes it was a little tight, but it wasn't that bad.... I just pulled the carpet back a little to get the pedal board out. I am a big guy...cant stand getting stuck in there. rich |
Tom_T |
Apr 5 2010, 02:42 PM
First off...Call George and have him put two cables on your order... Put the spare one in the trunk...you will thank me someday within the next 5 years. Remove drivers side carpet. Remove plywood pedal board..it does come out, a few allen head bolts and it really does come out without breaking it....its just a bit of an odd puzzle... If you have a center console...remove it and put it on the passenger floor. Remove the cable end that attaches to the gas pedal on the pedal cluster. Pull out the broken end via the front. Disconnect the cable at the throttle body and feed it under the car. Pull it out of the tube. Slide new one in (greased and lubed) Hook it all back up. (IMG:style_emoticons/default/agree.gif) The only thing to add is check and make sure you don't get it wrapped around the clutch cable when installing. Before putting the pedal board back in start it up and push in the clutch and see if it revs up any..... Another thing to add is to check the condition & connection of the ground strap off the transaxle, to make sure that you're not frying your acc. cables by them ending up as your only ground for the engine!! Either Gemo (stock) or Terry should last just fine for a DD etc., so long as the drivetrain is grounded. Replace that strap & connecting bolts/screws as well if needed & clean everything up as you would for battery posts/cables & coat with the battery terminal grease to keep a good connection! Then hopefully you won't need another acc. cable in your front trunk (along with that spare fan belt btw) for more than 5 years! My Gemo is still good after 30 years! ... of course the last 25 were on blocks in my garage! (IMG:style_emoticons/default/biggrin.gif) Seriously though, I'd only replaced it once Dec 75 - May 85 over +/- 130k of DD (only car) use out here in supposedly dry SoCal. (IMG:style_emoticons/default/shades.gif) |
jeffdon |
Apr 5 2010, 04:06 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
First off...Call George and have him put two cables on your order... Put the spare one in the trunk...you will thank me someday within the next 5 years. Remove drivers side carpet. Remove plywood pedal board..it does come out, a few allen head bolts and it really does come out without breaking it....its just a bit of an odd puzzle... If you have a center console...remove it and put it on the passenger floor. Remove the cable end that attaches to the gas pedal on the pedal cluster. Pull out the broken end via the front. Disconnect the cable at the throttle body and feed it under the car. Pull it out of the tube. Slide new one in (greased and lubed) Hook it all back up. (IMG:style_emoticons/default/agree.gif) The only thing to add is check and make sure you don't get it wrapped around the clutch cable when installing. Before putting the pedal board back in start it up and push in the clutch and see if it revs up any..... Another thing to add is to check the condition & connection of the ground strap off the transaxle, to make sure that you're not frying your acc. cables by them ending up as your only ground for the engine!! Either Gemo (stock) or Terry should last just fine for a DD etc., so long as the drivetrain is grounded. Replace that strap & connecting bolts/screws as well if needed & clean everything up as you would for battery posts/cables & coat with the battery terminal grease to keep a good connection! Then hopefully you won't need another acc. cable in your front trunk (along with that spare fan belt btw) for more than 5 years! My Gemo is still good after 30 years! ... of course the last 25 were on blocks in my garage! (IMG:style_emoticons/default/biggrin.gif) Seriously though, I'd only replaced it once Dec 75 - May 85 over +/- 130k of DD (only car) use out here in supposedly dry SoCal. (IMG:style_emoticons/default/shades.gif) How come someone has not come up with a cable with non-conductive ends? That way it could not conduct current.... |
Lo-Fi Version | Time is now: 31st May 2024 - 08:37 PM |
