Two New Mods, One for Many of the Unfortunate.... |
iiibdsiil |
Mar 30 2004, 11:39 PM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
(IMG:http://victorian.sytes.net/brett/pictures/914jackstands-small.jpg)
Larger Just kidding to all of those that don't get to drive their 914s. Just getting ready for an oil change tomorrow. And... (IMG:http://victorian.sytes.net/brett/pictures/NewTach_small.JPG) The tach went in real easy. Took about 15 minutes. |
Brad Roberts |
Mar 30 2004, 11:43 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Yep. I use that tach also.. slips right in. I cut the old rubber "band" from the old tach and modify it to work with the Autometer.
B |
iiibdsiil |
Mar 30 2004, 11:46 PM
I didn't have to cut mine. Just a little bit of KY Jel... errr... vasoline.
- Brett Smith |
Eric Taylor |
Mar 30 2004, 11:51 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Your pretty dam lucky driving your car and all. I wish all I had to do was an oil change! Is your car idiling high? Or is the tach off?
Eric |
iiibdsiil |
Mar 31 2004, 12:02 AM
Tachs off. But it does idle high, just not that high.
Sorry about yours. |
Brad Roberts |
Mar 31 2004, 12:08 AM
The tach is what we call a "tell tale" it records the highest RPM before you shut the car off. His tach should have a "reset" button on it to clear it.
B |
machina |
Mar 31 2004, 06:48 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
What model is that?
How does it connect to the ignition on a car with webers. I love the old porsche gauges but the redline on my new motor will be >7500, so have to start thinking about a new tach. There are porsche tachs that go to 8k and 10k but they are much $$$, and probably not as accurate as your autometer. dr |
iiibdsiil |
Mar 31 2004, 07:04 AM
It is Autometer Autogage. 5 inch. With no external shift light, it is 99$. It is dead on. I never realized my factory one was shot until I had this one.
I am not sure on how to hook it up in your situation. I believe I have an electronic (computer) tach signal, but if Porsches are anything like the GMs, you can hook up to the negative on the coil. |
Lo-Fi Version | Time is now: 13th June 2024 - 03:09 AM |
