| jimkelly |
Apr 8 2010, 08:03 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i was wondering?
jim |
| URY914 |
Apr 8 2010, 08:22 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 134,363 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
No one should be.
| underthetire |
Apr 8 2010, 09:37 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
| Cap'n Krusty |
Apr 8 2010, 09:38 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
| realred914 |
Apr 9 2010, 10:50 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
i believe it is PMB that does 914 brake work, i know they do the calipers, give them a call. I dont have his number right now. sorry
or suggest you call rich at 650 364-6234 and see what he has to offer. he does sell the calipers that PMB rebuilds so he should know. |
| 914Sixer |
Apr 9 2010, 11:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,545 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Proportioning valves can be redone by Wilhoit Restorations in Long Beach, Ca, They do mostly 356 stuff but advertise redoing prop valves.
| realred914 |
Apr 9 2010, 11:46 AM
| Joe Bob |
Apr 9 2010, 12:19 PM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Take the P-Valve out and put in a tee from a VW squareback....go with a new 19mm 911 master. They are cheap.
| URY914 |
Apr 9 2010, 01:20 PM
| streetrover |
Apr 11 2010, 12:12 PM
Member ![]() ![]() Group: Members Posts: 87 Joined: 22-December 09 From: Inland Empire Member No.: 11,163 Region Association: Southern California |
| Joe Bob |
Apr 11 2010, 06:30 PM
65/35 or thereabouts bias to the front. Keeps the rears from locking up before the fronts, which is a BAD thing. Removing the valve brings it closer to 50/50 as the front brake pads are larger than the rears.
Going to bigger calipers on the fronts is good thing with the valve removed. |
| McMark |
Apr 12 2010, 12:35 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Technically speaking, it doesn't proportion anything. It's a limit valve. It keeps the pressure that's going to the rear brakes from rising above a certain level, whereas the fronts are free to keep rising. At low brake pressures you have the same pressure at the front as you do at the rear. A true proportioning valve would mean less pressure to the rears even as low levels.
Lo-Fi Version | Time is now: 12th August 2026 - 04:26 AM |
