jimkelly
Apr 8 2010, 08:03 PM
i was wondering?
jim
URY914
Apr 8 2010, 08:22 PM
No one should be.
underthetire
Apr 8 2010, 09:37 PM
QUOTE(jimkelly @ Apr 8 2010, 07:03 PM)
i was wondering?
jim
Masters are easy to re-build, but the seals kit are not available any more.
Cap'n Krusty
Apr 8 2010, 09:38 PM
i was wondering?
jim
No one in their right mind. Or, maybe, no one without massive liability insurance.
The Cap'n
realred914
Apr 9 2010, 10:50 AM
i believe it is PMB that does 914 brake work, i know they do the calipers, give them a call. I dont have his number right now. sorry
or suggest you call rich at 650 364-6234 and see what he has to offer. he does sell the calipers that PMB rebuilds so he should know.
914Sixer
Apr 9 2010, 11:35 AM
Proportioning valves can be redone by Wilhoit Restorations in Long Beach, Ca, They do mostly 356 stuff but advertise redoing prop valves.
realred914
Apr 9 2010, 11:46 AM
QUOTE(914Sixer @ Apr 9 2010, 10:35 AM)
they are no fly by night outfit either, they have a very good reputation in the 356 world
Joe Bob
Apr 9 2010, 12:19 PM
Take the P-Valve out and put in a tee from a VW squareback....go with a new 19mm 911 master. They are cheap.
URY914
Apr 9 2010, 01:20 PM
As Mr Suave said........
streetrover
Apr 11 2010, 12:12 PM
i was wondering?
jim
Just curious . . . what EXACTLY do these proportioning valves do? What happens if you eliminate the valve (as shown in the pix posted by URY914)?
Joe Bob
Apr 11 2010, 06:30 PM
65/35 or thereabouts bias to the front. Keeps the rears from locking up before the fronts, which is a BAD thing. Removing the valve brings it closer to 50/50 as the front brake pads are larger than the rears.
Going to bigger calipers on the fronts is good thing with the valve removed.
McMark
Apr 12 2010, 12:35 AM
Technically speaking, it doesn't proportion anything. It's a limit valve. It keeps the pressure that's going to the rear brakes from rising above a certain level, whereas the fronts are free to keep rising. At low brake pressures you have the same pressure at the front as you do at the rear. A true proportioning valve would mean less pressure to the rears even as low levels.
