Engine bay seal |
Engine bay seal |
jeffdon |
Apr 9 2010, 11:35 AM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
See attached....I believe the correct installation is with the V (red line) facing up, so that the downward bent flange on the tin will rest in this V. Am I correct?
realred914 |
Apr 9 2010, 11:44 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
See attached....I believe the correct installation is with the V (red line) facing up, so that the downward bent flange on the tin will rest in this V. Am I correct? exactly as you said, Vee down is it!!!!!!remember to use a big staple or a bit of bailing wire to tie off the two front most corners (the side pieces to the front peice) the factory had a big staple thru them to finish off the seal nice and tight. |
Mikey914 |
Apr 10 2010, 03:03 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You are correct. The V is down.
Lo-Fi Version | Time is now: 11th June 2024 - 09:14 PM |
