> 993 6-speed transmission?
post Apr 9 2010, 03:50 PM
Resident German
Can the R&P be flipped in a 993 transmission? I know they came in 5 and 6 speed manual.
From the looks of it, it should fit in a 914. The output flanges are a bit too far forward, but a slight angle on the axles shouldn't be a problem.
(IMG:style_emoticons/default/idea.gif) Andy
Replies(1 - 19)
pcar916
post Apr 9 2010, 04:04 PM
Is that a Lola?
I don't remember from rebuilding one 10 years ago if the case will do that, but G50's run upside down just fine. That's a lot easier than R&P flippin' since it's likely gonna be a cable shifter anyway eh?
Patrick motorsports (maybe others as well) has the short bell-housing version but I don't know if it's been fitted up to a 914. Surely someone's done it! Wonderful transmission. If it wasn't SO heavy.
Could be a good thread here! Who's doing it or finished one???
post Apr 9 2010, 04:10 PM
Resident German
QUOTE(pcar916 @ Apr 9 2010, 03:04 PM) *
It looks like running it upside down would require cutting the trunk. I'd rather not do that.
(IMG:style_emoticons/default/popcorn[1].gif) Andy
Porcharu
post Apr 9 2010, 04:12 PM
Might be easier to go with the 6 speed Subi. Not like your car is stock.
Steve
post Apr 9 2010, 04:14 PM
Resident German
QUOTE(Porcharu @ Apr 9 2010, 03:12 PM) *
Easier than mating a 993 transmission to a 993 motor using a 993 flywheel and 993 clutch?
(IMG:style_emoticons/default/biggrin.gif) Andy
pcar916
post Apr 9 2010, 04:21 PM
Is that a Lola?
QUOTE(SirAndy @ Apr 9 2010, 02:14 PM) *
Yeah, I still have my 993 flywheel and clutch pack (55lbs) and exhaust system, and power steering pump, and... Stuff's just been sittin' there for years taunting me.
No transmission though... nuts!
post Apr 9 2010, 04:34 PM
Resident German
QUOTE(pcar916 @ Apr 9 2010, 03:21 PM) *
I have a lightened flywheel and performance clutch package that came with my motor. Much lighter than the stock setup.
It's been collecting dust at McMark's shop.
(IMG:style_emoticons/default/shades.gif) Andy
McMark
post Apr 9 2010, 04:37 PM
914 Freak!
Boxster....
Steve
post Apr 9 2010, 06:32 PM
I have seen it done in PMS cars before. He flipped the trans upside and cut up the trunk. You mostly find them in tube frame cars.
RJMII
post Apr 9 2010, 07:04 PM
Jim McIntosh
QUOTE(McMark @ Apr 9 2010, 04:37 PM) *
Boxster....
This one is the Boxster S 6 speed
This one is Boxster 5 Speed
Do either of them look like they will bolt onto Andy's 993 engine?
Elliot Cannon
post Apr 9 2010, 08:37 PM
Group: Retired Members
Flipping this trans also raises the CG correct? Heavier and higher?
r_towle
post Apr 9 2010, 08:41 PM
Custom Member
Ask for a junk one at Easy...the take it apart and see...
I would suggest that you go for the new tranny that shifts in 1/1ooth of a second...
Rich
brilliantrot
post Apr 9 2010, 10:39 PM
A US 993 6 speed is called a g50/20. The diff can not be flipped on them so you have to run them upside down.
The are EXPENSIVE in relative terms to 901 and have terrible gearing stock. Figure ~$5k for a decent one and most don't have LSD. Gear sets are $1k each and only the early 1995 boxes came with a removable 2nd gear so add ~$2k for the equivalent of a 904 main shaft for a g50/20.
Did I mention they are ungodly heavy too?
The upsides of all this though are they do shift really well and hold a lot of power. If I were going to use one in a mid engined application, I would go with a 996/997 GT3 box as they are cable shift (much easier to route for a mid-engined application), have a decent LSD, are stronger, and have much better ratios.
Another option is to buy a g50/31. This is the gear box out of a 993RS and it has better parts and better gearing. Last I heard they were ~$13k from Sunset which is much cheaper than one could build one like it.
McMark
post Apr 10 2010, 08:09 PM
914 Freak!
Yes, but I have 'Modification Goggles'. (IMG:style_emoticons/default/cool.gif)
Where there's a will there's a way.
Andyrew
post Apr 10 2010, 08:11 PM
Spooling.... Please wait
QUOTE(RJMII @ Apr 9 2010, 06:04 PM) *
Boxster....
Looks like it'll bolt to my Audi 1.8T engine.
Oh wait, thats because it will! (IMG:style_emoticons/default/biggrin.gif)
sww914
post Apr 10 2010, 08:46 PM
So will an Audi 1.8t engine bolt to a 993 engine? (IMG:style_emoticons/default/smile.gif)
RJMII
post Apr 10 2010, 09:06 PM
Jim McIntosh
QUOTE(Andyrew @ Apr 10 2010, 08:11 PM) *
Which one you looking at?
RJMII
post Apr 10 2010, 09:09 PM
Jim McIntosh
QUOTE(McMark @ Apr 10 2010, 08:09 PM) *
I like your goggles. =o) If you get one and start modifying it; I have a few questions. Could you PM me if that happens so I don't hijack one of Andy's threads? Or if you have one and don't mind answering a couple of measurement questions...
Andyrew
post Apr 10 2010, 10:30 PM
QUOTE(RJMII @ Apr 10 2010, 08:06 PM) *
The B5 Audi FWD transaxle's are the same bolt pattern to the boxster trani's, Not sure which one, but thats what Felix is running on his NEO car..
Mike Bellis
post Apr 11 2010, 03:27 PM
Resident Electrician
Just put new cams in the 3.6 and make it spin backwards (IMG:style_emoticons/default/poke.gif)
- Lo-Fi Version Time is now: 31st October 2024 - 06:35 PM
