brake light switch, how does it work |
nycchef |
Apr 11 2010, 07:07 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
i put in a rebuilt pedal cluster today and have a question about the brake light switch. where is the metal tab supposed to sit? am i correct in thinking that it sits in front of the piston and tiggers the light when the piston moves back and breaks contact? or am i nuts as always a pic would help
jt914-6 |
Apr 11 2010, 07:26 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
As in the pic. The washer #48, goes next to the eyelet, then the lock nut on it. The washer goes to the rear of the brake light switch lever. When the pedal is pushed, the washer makes the switch activate and the tailights come on.....# 25 is the adjustment screw. Adjust for the lights to come on just after you push the pedal.
nycchef |
Apr 11 2010, 08:26 PM
As in the pic. The washer #48, goes next to the eyelet, then the lock nut on it. The washer goes to the rear of the brake light switch lever. When the pedal is pushed, the washer makes the switch activate and the tailights come on.....# 25 is the adjustment screw. Adjust for the lights to come on just after you push the pedal. thanks i may have it right |
oz371 |
Apr 11 2010, 09:10 PM
Member Group: Members Posts: 101 Joined: 28-August 09 From: ontario, CA Member No.: 10,739 Region Association: None |
As in the pic. The washer #48, goes next to the eyelet, then the lock nut on it. The washer goes to the rear of the brake light switch lever. When the pedal is pushed, the washer makes the switch activate and the tailights come on.....# 25 is the adjustment screw. Adjust for the lights to come on just after you push the pedal. thanks i may have it right This is great. I was just about to post a question about my brake lights which do not come on until the pedal is pretty far down. Thanks!! (IMG:style_emoticons/default/piratenanner.gif) |
ArtechnikA |
Apr 12 2010, 03:54 AM
Well, ok, maybe...
In my cars, the brake light switch turns the brake lights -off-. It is a 'NC' - Normally Closed switch. If the switch falls out of position or the little finger bends or breaks, the lights will stay on. When the pedal is 'at rest' the circuit is opened and the lights go off. |
Lo-Fi Version | Time is now: 12th June 2024 - 09:43 PM |
