trojanhorsepower |
Senior Member ![]() ![]() ![]() Group: Members Posts: 885 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None ![]() |
Can anyone tell me where #23 goes? I can not find the download page for the wireing diagram. I don't know how I lost it, but it is cut now so I need the other end. I have the ECU end.
Thanks -Pete |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i dunno if there's a difference between the years but my '70 (early) diagram sais:
wire #23 from the brain goes to: (77) = Temperature Sensor II which implies there's a Temperature Sensor I (IMG:style_emoticons/default/wink.gif) it's actually on the map too, Sensor I is in line between Brain Wire #1 and #13 ... soooo, Sensor II it is, (IMG:style_emoticons/default/smile.gif) Andy |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Isn't temp sensor 2 the CHT and temp sensor 1 is for the intake air temp sensor?
SirAndy |
QUOTE(Bleyseng @ Mar 31 2004, 08:04 PM) Isn't temp sensor 2 the CHT and temp sensor 1 is for the intake air temp sensor? dunno which one is which ... but if only one connection is missing he shouldn't have any trouble finding the one that's NOT connected. (IMG:style_emoticons/default/wink.gif) Andy |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,969 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
You all got it dudes....for aLL D-jet systems:
23 off the ECU connector is for TS2 = CHT sensor. look for a single white wire with a long blade male wire terminal. 1+13 are the TS1 connections....intake air temp sensor. |
Bleyseng |
Yes Master (IMG:style_emoticons/default/pray.gif)
trojanhorsepower |
Thanks guys!
I was having trouble with that one, because I could not trace it. The harness is out of the car (along with everything else) and I am trying to piece it back together. Thanks again -Pete |
Lo-Fi Version | Time is now: 7th July 2025 - 08:08 AM |
