| yeahmag |
Apr 24 2010, 03:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,483 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California
I just picked up a set of Koni Yellow's for the rear of the car (used of course). While my Koni Red's have a 1.5 thread pitch for the threaded insert, the yellows have a 1.25. Is that normal? If so where do I get the threaded insert in a 1.25 tp?
Thanks! |
| yeahmag |
Apr 24 2010, 03:13 PM
I should mention these are labeled
Koni 8241 1050 Sport |
| Eric_Shea |
Apr 24 2010, 05:05 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE for the rear of the car Rears - Threaded Insert? Rears are shocks not inserts. Which threaded part are you talking about? (IMG:style_emoticons/default/confused24.gif) |
| yeahmag |
Apr 24 2010, 05:58 PM
Correct... This is rears. The threaded insert I'm talking about is the T shaped piece that threads on to the top of the shock that has the rubber bushings on it at the top of the shock.
| RJMII |
Apr 24 2010, 07:19 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I don't recall any "T" ?
do you see it in the pictures of my Koni Yellow? Attached image(s)
| Eric_Shea |
Apr 24 2010, 08:28 PM
I know what he's talking about. Sorry, when you said "insert" I thought you were talking about the common collar issue with inserts.
Odd. Should have come with something. I'll check to see what I have. |
| yeahmag |
Apr 24 2010, 08:55 PM
This is the piece...
| 914ohana |
Sep 2 2010, 12:23 PM
Newbie ![]() Group: Members Posts: 16 Joined: 11-December 09 From: Mt. Hood, OR Member No.: 11,115 Region Association: Pacific Northwest |
| DanT |
Sep 2 2010, 05:49 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
I had the same issue when I installed these....
I retapped the aforementioned piece and then found two new nuts with the correct thread for the top... Worked fine.. Attached image(s)
| Eric_Shea |
Sep 2 2010, 08:40 PM
My, my, my... those look beautiful (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/lol3.gif)
Sorry I couldn't come up with a fitting. Mine are "almost" done. TrueChoice has been "dicking" around with them. Film at 11:00 Hey, how do they ride? |
| DanT |
Sep 2 2010, 09:06 PM
Eric,
on full soft with the 140# rear springs they are just about like a normal 914 ride... on full stiff, they are going to be great at the AX.... After an event I will see if I can get the balance right with just the shocks and air pressures...if not then I may look for a rear bar to get the back end to rotate. I always like a car that is a bit loose...Kind of freaks out some of my students, but that is the way I like it, especially in a low powered momentum car (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) This winter I plan on doing a little detailing on the trailing arms and associated stuff (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 10th June 2026 - 03:48 AM |
