East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,866 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
I just received these hubs that I bought off ebay(from someone on this board to remain nameless for now) and there appears to be a substantial wear area on one of the bearing surfaces. I can't believe this would be a "normal" thing, has anyone seen one like this?? The worn area is .020 smaller in diameter than the non worn area. The add stated they were in "LIKE NEW condition".??? It's actually kinda strange cause if it spun a bearing I would think the wear area would be the width of a bearing race. It almost looks like someone machined it to hide damage,
I believe these are unusable, unless someone can convince me otherwise. (IMG:style_emoticons/default/confused24.gif) Attached File(s) |
East coaster |
Here's the diameter of the non-worn area.........
Attached File(s) |
East coaster |
here's the diameter of the worn area........
Attached File(s) |
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
I don't think what you are measuring there is a bearing surface. The rear cartridge bearing slides on there but the bearings ride on the race that's included with the bearing.
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,992 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
QUOTE(East coaster @ Apr 1 2004, 06:59 PM) The add stated they were in "LIKE NEW condition".??? That means there's no surface rust! (after sandblasting them) (IMG:style_emoticons/default/blink.gif) Actually I don't think there's anything wrong with the groove being there, as long as the hub slides into the bearing with a little resistance. Any machining to that surface will render them totally unusable and you will know it right away during installation. |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,109 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
As long as they go on there tight and are a royal pain in the butt to get on like normal I dont think that they would be a problem.
The only way that they would be a problem is if the inner bearing race didnt fit tight and they were able to slip when the bearing inside is rotating. |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Ill have to go dig out a pair of stub axles... but from what I see dont worry about it..
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Is that a step or a groove?
If it's a step....half the seating surface is .02 smaller that the other half, they are toast. If it is a .05/08 or so wide groove....as it appears in the top pic, they'll work. |
garyh |
Member ![]() ![]() Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 ![]() |
That groove lines up with where the inner race is split.
How it got there is a mystery. But like others, I wouldn't worry about it. Do check for cracks on the tip. Little hairline cracks show up there, and make it useless. Also verify that they are a -snug- fit with new bearings. If they were blasted, and -any- metal was taken off from there, they're toast. Unfortunately, all real testing requires the axle nut to be torqued. G. |
East coaster |
Sorry, Maybe I should've explained it better. What you see in the first pic is not a groove, but a ridge where from that ridge to the base of the hub it is .020 smaller in diameter than the other half of the bearing surface. With this, I would think that the bearings inner race would be swingin' in the breeze for 1/2 the width of the bearing?? It almost looks like someone turned it down in a lathe, I think they're junk!
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
can they be tig'd and machined?
415PB |
Member ![]() ![]() Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 ![]() ![]() |
Yep, I agree. See if they will take them back......
ChrisFoley |
I thought it was just a groove. If the inner half of the bearing surface is as you say, then it is useless and I suggest you expose the perp here and now so we can stone him.
There is no excuse for such false advertising. (IMG:style_emoticons/default/chair.gif) |
East coaster |
I think it's only fair to let them make good on this before I flame them on the board. I'm really surprised by this, they seemed reputable. I'll report back here after giving them the opportunity to fix this......stay tuned!
ChrisFoley |
QUOTE(East coaster @ Apr 1 2004, 08:09 PM) I think it's only fair to let them make good on this E-mail him the link to this thread and give him a deadline to respond publicly. "Like new condition" my ass! |
415PB |
If it's the vendor I think, because I was going to bid on these hubs, I am sure they will make good on the deal. If they dont then they can (IMG:style_emoticons/default/pissoff.gif)
Rich Bontempi |
914 Road Racer ![]() ![]() Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California ![]() |
That hub, should not be used, get a good one!
East coaster |
Ok.....so now I need another set of 1970 914 hubs. Does anybody have a set of the early hubs with both the 4 and 5 lug bosses available. I had a set of 914-6 stubs and was going to use 911 hubs, but I sold my damn stubs when I bought these, so now I'm stuck looking for another set of 1970 914 hubs! Anybody got a set available???
BTW - The seller has contacted me and is willing to accept the return of the hubs. I'll accept that the seller didn't realize the condition and didn't mean to misrepresent the item. This was resolved quickly and I would do business with them again! No need for any flames! (IMG:style_emoticons/default/blowtorch.gif) |
ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
Sounds like you've been around the block a few times on your 5 lug conversion attempts. FYI, you can have plain vanilla 4 lug hubs drilled and studded for 5; I've been running a set of these for a couple years now through multiple DE's / AX's with no trouble. I had Patrick Motorsports do the mod, though any 914 savvy machine shop can do it; both Patrick and the related PP tech article say they're strong enough.
If you wind up with a set of 914-6 stubs again, I have a set of early 911 hubs available. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,631 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
how soon do you need them? I have a 1970 parts car in the driveway but I won't be able to get in the garage for 3 weeks or so.
- Garold |
Lo-Fi Version | Time is now: 31st July 2025 - 01:53 PM |
