> Rear Hubs, How about welding for 5 lug conversion
914gem
post Apr 1 2004, 09:13 PM
Has anyone tried building up the metal like on the 70 hubs by welding? I hear so many people crying how thin the later hubs are. Any ideas on if this would work or not?
Replies(1 - 3)
Bleyseng
post Apr 1 2004, 09:15 PM
Aircooled Baby!
I am sure you can add material and then machine it off but that sounds expensive. Find a good set if you have to have them, I have a set stashed. The regular hubs have enough material for the studs if you tack weld them to the hub after the stubs are inserted. I only think the early hubs are needed if you AX alot or race with wide tires. (stress)
Geoff
914gem
post Apr 1 2004, 09:24 PM
I have 4 sets of 70 hubs but I have a No3 wash tub full of the later hubs, just trying to figure out what to do to make them better.
Bleyseng
post Apr 1 2004, 09:30 PM
Aircooled Baby!
Why, just machine flat the surface where the stud mounts for the 5 bolt pattern and then after drilling the proper size hole, press in the studs. Lots of metal for that.
Geoff
- Lo-Fi Version Time is now: 15th April 2026 - 11:18 PM
