| Ray Warren |
Apr 2 2004, 07:16 PM
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
What do you guys think of this engine?
Does it compare to the engine a couple of threads down? Less than 1000km, currently in car, can be heard and driven. 2056cc T4, based on original 914 2.0 engine (GA case, correct heads, windage tray) 9.5:1 CR All rotating parts precision balanced new NPR 96mm pistons, rings, and liners. Big valves, ported, incl new valves, valve guides, new HS springs from FAT performance. Heads flycut, chambers cc'd all new std bearings (crank not ground) rods resized and bushed, new rod nuts new 911 clutch, rebuilt PP, newly resurfaced flywheel. Again all balanced as a unit with crank and other rotating bits genuine OE porsche 911 'elephant foot' valve adjusters new FAT performance HD rocker studs. new FAT performance street cam - .495" 290 deg, new cam gear of course, new lifters new FAT blueprinted oil pump New Eurorace shorty intake manifolds, match-ported for DCNFs and T4 head. Stainless steel heat exchangers new Mallory distributor and new mallory Hyfire 6 AL ignition (price those up....) completely rebuilt Weber 42DCNFs New K&N filters fancy Accell sparkplug wires Blasted and repainted tin, new hoses , etc, etc, etc... |
| machina |
Apr 2 2004, 07:23 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
Looks like a good rig to me.
The GA case is no big deal, they're pretty much all the same. Wondering about the DCNF carbs, why not IDF's, anybody know? probably cost 6k to build it. dr |
| Mark Henry |
Apr 2 2004, 09:38 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
The DCNF's are a real good street carb, but I wouldn't use them in a teen. Going through the twisties will upset them and you can never do AX or track with them. The IDF's have a superior float bowl design. Also the T4 DCNF manifolds are quite short, good for down low, but top end will suffer, you would gain a fair bit by using velocity stacks.
This may be my opinion but I have 2 sets (bug and squareback) of DCNF's, so I have a lot of experience with them. The SS exchangers will work OK but a header would gain you some ponies. That would be a 911 clutch disc only. The rest sounds good. What cam? So...how much? |
| Bleyseng |
Apr 2 2004, 09:45 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Have it dyno'd then offer some money for it based on the results.
| Mark Henry |
Apr 2 2004, 09:48 PM
A DCNF with velocity stacks.
| Tom Perso |
Apr 2 2004, 10:19 PM
Crazy from the Cold... ![]() ![]() ![]() Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Dump the dcnf's.... They stink in the twisties...
Later, Tom |
| rhodyguy |
Apr 2 2004, 10:24 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
how much is it?
kevin |
| Ray Warren |
Apr 3 2004, 05:52 PM
$4000 CDN
| Ray Warren |
Apr 3 2004, 05:57 PM
Mark you might know this engine.
I think Mike worked on the car. It looks like Mikes shop in the background. |
| MattR |
Apr 4 2004, 03:09 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Is that a canadian flag on the coil? (IMG:style_emoticons/default/ohmy.gif)
| Mark Henry |
Apr 4 2004, 07:52 AM
Yep, I've driven it! It's Dave Syer's engine.
Good engine, about as fast as my squareback, so it's around 120hp. Mileage would be correct as Mike just finished the resto on it last June/July. That's Mike's (Mikes 914, local shop) old shop in the background. When they did the resto they installed a /6 bulkhead mount, so I take it Dave found a six to put in it? It's a good deal but I would still change the carbs. You should be able to sell them to help offset the price of a new set of 44IDF's. The DCNF's are a good carb and I think they have the float valve upgrade, but they would be better off in a street Bug, bus or a T3. My DCNF's in the squareback are real Berg and they still hiccup in fast corners. I wasn't crazy about the linkage as well, but that would be an easy fix. If it includes the exhaust it's a total score. The engine is fresh, all the tin, etc. is restored, so I'd say that 4k Canadian (about $3000USD) is a good price. QUOTE Is that a canadian flag on the coil? We canucks are proud of our old flag as well (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 13th November 2026 - 10:34 AM |
