Does anyone need good sheet metal, cutting up, going fast |
Gigamight |
May 6 2010, 10:50 AM
Member Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East |
I already posted, and got no responses. I am giving one last chance to get some pieces if you need them.
I am trying to cut in order to save the entire rear trunk floor and the suspension consoles. This car had very little use, and so has almost no rust, and no thru-rust that I have found. I have saved the tail light panels and I am trying to save the rear door jambs as well. If nobody needs any of this car, then I will stop trying to save anything and just keep what I want (the tunnel and rear floors) If there is a part you need, please contact me asap and I will try and save it for you. I am currently dealing with handling the affairs surrounding my father's death, so I may not be on here often, so if you are serious and need something saved asap, call me 3 3 0 - 3 two 8 - 8 5 5 two |
db9146 |
May 7 2010, 09:51 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
How does the front trunk floor look? I need to fix an AC condensor hole. I was looking for the entire front trunk floor to be able to make a nice seam and hide as much of it as I could.
Thanks |
Gigamight |
May 7 2010, 01:35 PM
How does the front trunk floor look? I need to fix an AC condensor hole. I was looking for the entire front trunk floor to be able to make a nice seam and hide as much of it as I could. Thanks I am cutting 2 actually. The one I am referring to in this thread had a front-ender, so the front floor is buckled. The other one I am cutting up might work, but I need you to send me a pic of the hole you are repairing so I can make sure it would work. |
SirAndy |
May 7 2010, 01:55 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Ah craps, i need a front trunk floor as well ...
2nd if db9146 does not want it. (IMG:style_emoticons/default/beerchug.gif) Andy |
zy84 |
May 7 2010, 03:24 PM
Newbie Group: Members Posts: 23 Joined: 12-February 10 From: Brownsville, TX. Member No.: 11,354 Region Association: None |
Would you happen to have a cowl section that is not rusted. Mine has a whole on each side where it meets the fender.
entomologist2004 |
May 11 2010, 04:55 PM
Newbie Group: Members Posts: 3 Joined: 30-June 08 From: Eureka, CA Member No.: 9,236 Region Association: None |
I need the firewall for a 73 (IMG:style_emoticons/default/sawzall-smiley.gif)
Let meknow what you want for it . Shipping via Greyhound is workable or ?? |
Jacob |
May 11 2010, 06:14 PM
Member Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
I need the front panel that the bumper bolts to.
Markl |
May 11 2010, 08:46 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
I am looking for door jambs - decent? How much?
72914S |
May 11 2010, 08:51 PM
love this shot Group: Members Posts: 1,290 Joined: 10-July 03 From: Pensacola,Fl. Member No.: 900 Region Association: South East States |
I`m in need of the front floor area where the pedal assembly bolts down. From side to side, it`s the curved piece. Mine is swiss cheese. Barry
Rav914 |
May 12 2010, 11:19 AM
All-weather fan Group: Members Posts: 738 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
Looking for a section of the front driver's side fender. The wheel well lip and about fourish inches of metal, all the way around. See attached picture. To the side marker light would be the extent I would need.
Need the metal to be nice and uniform, no dents. Thanks. Attached image(s) |
bigkensteele |
May 12 2010, 10:13 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I might need a rear trunk floor. What year is it?
Lo-Fi Version | Time is now: 8th June 2024 - 11:32 AM |
