rsrguy3 |
Member ![]() ![]() Group: Members Posts: 136 Joined: 4-April 09 From: Utah Member No.: 10,234 Region Association: None ![]() |
Is there a list of alternative internals(non-vw) for our rebuilds that would make our re-builds cheaper and stronger, Example... Chevy rods. Consider this a tips and tricks thread, as well. Also, I don't have good experiences w/the forum search, so please place as many links as you can dig up, here. (IMG:style_emoticons/default/biggrin.gif)
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I got 2 squirrles, a penguin and a raoch stuffed in there. You should hear that motor scream...
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
KB 96mm Hyperutectic Aluminum pistons, stock Mahle cylinders machined to 96mms and Raby 9550 cam...the rest was stock and worked well together (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) ![]() ![]() ![]() |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,765 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I used the same pistons and cylinders for my 2056. I am also using ceramic lifters instead of steel (NLA, but great if you can find them). My engine is carbed, so I have more choice in dizzys. I am using a Mallory Unilite, and a Bosch Blue coil. Zach |
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
warrenoliver |
Member ![]() ![]() Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest ![]() |
KB 96mm Hyperutectic Aluminum pistons, stock Mahle cylinders machined to 96mms and Raby 9550 cam...the rest was stock and worked well together (IMG:style_emoticons/default/biggrin.gif) Dan, Did you dyno your engine after these improvements? I am wondering what kind of HP increase I can expect if I go this route with my 2.0. I am not ready to go all in on a Raby 2270 but I sure would like to (IMG:style_emoticons/default/drooley.gif) - I just can't afford it right now. What kind of HP increase over stock 73, 2.0, with FI, could I expect with new pistons/cylinders and a Raby cam? Anyone have any idea on cost for this type of "improvement"? Warrenoliver |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
2056 motor are a blast compared to any stock motor.
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
My 2056 consists of Kieth Black pistons, AA cylinders, Hastings rings, Raby 9050 cam and valvetrain, 1.7 rockers with swivel adjusters, 2.0 heads, Manton pushrods, stock crank, H-beam connecting rods.
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Those are some nice engines!
With regards to HP, 95 to 115, or 95 to 125, especially with some suspension improvements and weight reduction makes a big difference... |
rsrguy3 |
So, which Chevy rods are used? And what about the Buick crank? Loving the pics guys keep it up.
TROJANMAN |
Looks nice in pictures......... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,275 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None ![]() |
The most popular conversions are :
Porsche 6's, Chevy 8's, Suby 4's Here's my 2.7 (IMG:http://www.914world.com/bbs2/uploads_offsite/209.85.48.8-1753-1273768804.1.jpg) More Pics of Conversion |
xperu |
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None ![]() ![]() |
My 2056 consists of Kieth Black pistons, AA cylinders, Hastings rings, Raby 9050 cam and valvetrain, 1.7 rockers with swivel adjusters, 2.0 heads, Manton pushrods, stock crank, H-beam connecting rods. ![]() Hey george, what type and model are you using for that nice power plant? Mike |
70_914 |
Member ![]() ![]() Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest ![]() |
A lot of performance VW's use SBC valve springs after a lot of machine shop time, but all the other parts are specific for the engine. There are a lot of counterweighted cranks machined for SBC rod journals, but not SBC rods.
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
QUOTE 2056 motor are a blast compared to any stock motor. (IMG:style_emoticons/default/agree.gif) 9.5:1 CR + 10# flywheel=hang on (IMG:style_emoticons/default/smile.gif) I am running AA piston cylinders, webcam 163, dual spring valves, stock 2.0 crank and rods, 911 adjusters. you would not believe what shaving 7 lbs off the flywheel does... |
rsrguy3 |
Just for clarity..... I'm talking about the type 4 motor and it's internals. |
rsrguy3 |
A lot of performance VW's use SBC valve springs after a lot of machine shop time, but all the other parts are specific for the engine. There are a lot of counterweighted cranks machined for SBC rod journals, but not SBC rods. So, your saying no Chev con's, just journals? The reasoning behind this? How about the Buick crank? Is there a con rod made for a different motor, like a v8 motor that dimensionally similar/stroke (you know get 8 for 4)? (IMG:style_emoticons/default/dry.gif) |
azbill |
Member ![]() ![]() Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region ![]() |
I am running a 2056 with Keith Black pistons, Len Hoffman heads, Raby cam, stock crank and rods, Jennvey 45mm throttle bodies, Emerald M3D FI management, SS heat exchangers and Triad exhaust. The set-up dynoed 150hp at the wheels. Its great.
Bill |
Lo-Fi Version | Time is now: 31st July 2025 - 07:19 PM |
