914/6 color code for gauges |
quick six |
May 16 2010, 09:16 AM
Newbie Group: Members Posts: 22 Joined: 4-January 05 From: Paso Robles, Ca. Member No.: 3,406 Region Association: Central California |
I need to know what wiring colors goes where on the oil temp/fuel etc gauges. Tac & speedo ok.
My factory manuels have great flow charts & diagrams for the 4cyl but only a b/w of what connections/holes are what on the 6. Help please. Thanks gf (IMG:style_emoticons/default/unsure.gif) |
detoxcowboy |
May 16 2010, 08:13 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I have not the 6 nor know much about it but if you look at your gas tank, take off whatever to get to the sender (on a 4 it is only 2 x10mm bolts to get there) the colored wires for the fuel will be there with ground/sender markings to match what you need to do on the reveres of gauge.. Then by deduction the left over wires would be for the oil temp (switched power/ground and sender) brown is ground, switched power has power with key turned, the last wire is your oil temp sender..
you do not need pic or manual really.. |
BigD9146gt |
May 17 2010, 02:03 AM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
Thankfully, Porsche was consistent for all of the early 70's cars. I'll check tomorrow, this is from memory...
Tach signal: Black/Purple Generator: Blue (light blue) fuel level: Green fuel low level warning: black oil pressure: Green/Red oil temp: Green/Black oil level: Green/White |
quick six |
May 20 2010, 05:44 PM
Thankfully, Porsche was consistent for all of the early 70's cars. I'll check tomorrow, this is from memory... Tach signal: Black/Purple Generator: Blue (light blue) fuel level: Green fuel low level warning: black oil pressure: Green/Red oil temp: Green/Black oil level: Green/White Ok Thanks I figured the temp and fuel but have the low fuel light (I ran it down to see)in the hi temp light spot..Generator ok. Park Brake ok.Now to check out the rest of the lights Will see about the restThanks again. GF |
Jeffs9146 |
May 21 2010, 09:33 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Maybe this will help! The bottom cluster on this is the 6 cluster!
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 08:51 AM |
