Six Conversion, 55 amp Bosch Alternator Question |
bcheney |
May 16 2010, 11:51 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
I have a 55 amp Bosch alternator that has been rebuilt that I am installing into my 914/6 conversion car (Carbed 2.2 motor running MSD box and standard "points" distributor). I am trying to ID all of this Alernators stud connector posts and spade type connector posts. Can anybody assist? I am especially curious about the two spade type posts near the bottom center of the photo. One had a brown wire and one was black. If you can ID all posts for me that would be great as well. Thanks
Attached image(s) |
effutuo101 |
May 16 2010, 12:40 PM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
This is from memory, but:
Relay board: from Alt. ___ D- ___ ____ DF D+ Regulator plug in | DF Black/Green | D- Brown | D+ (+61) Grey Red Alternator wiring: DF= Black/Green D- = Brown +61 (D+) = Grey/Red B+ = Battery I will go check later today. |
rfuerst911sc |
May 16 2010, 01:22 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Brian I can't help with the wiring as you know I had Donnie do it all. My car is running great you need to stop buy and we'll go for a spin. Good luck with yours. (IMG:style_emoticons/default/beerchug.gif)
bcheney |
May 16 2010, 01:30 PM
Cool I will do that. I heard there was a PCA autocross today at the convention center...did you happen to go?
bcheney |
May 17 2010, 05:34 AM
Anyone know where the wiring from DF terminates?
jt914-6 |
May 17 2010, 05:43 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
IronHillRestorations |
May 17 2010, 07:17 AM
I. I. R. C. Group: Members Posts: 6,726 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
D-, D+, and DF go to the voltage regulator, which you'll need for that alternator. The two spade termainals that are close together require a connector plug body, and go to the VR. Sorry I can't remember off the top of my head which terminal/color they are. 914-4's and 6's aren't the same color, but wire up the same. I'll get back later with the correct connections. B+ goes to the starter/battery lead.
BigD9146gt |
May 17 2010, 09:07 AM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
I just did this a week ago...
B+: 911 engine harness will have a large red wiring from the starter to the alternator, and then a medium red wire (crimped to the same eyelet on B+) that will go to the 14pin plug. Pin #14 on the 911 engine harness, not sure what the 914 relay plate is cause I'm not using one of those, but not hard to swap around. DF: Black, goes right to the voltage regulator. Pin #13 D-: Brown, ground. I ran this directly to the vr, and then straight to ground... however the 911 harness has it running back and forth to many units all grounding, so it can be shared. Pin #12 D+/61: Blue. Straight to the vr, then from the vr to your generator light in the dash. Should still be blue wire in the 914. Pin #11 Using that very nice diagram jt914-6 supplied, all you need to do is pull the brown, black, and blue wires out before the plug (which looks like its only a 12 pin), and crimp on some spade connectors, and shove them into the plastic 914 3 pin alternator connector. Then your large red, I'd need a better defined pic of that diagram, but I'm sure you can find a home on the board for it to make it a clean setup. |
May 17 2010, 12:51 PM
The two spade connectors that are close together are:
vertical - black wire to DF horizontal - brown wire to D- If I make a harness for an engine with a externally regulated alternator, I run the blue wire that goes to the charging light all the way to the D+ terminal, so if you ever change to an internally regulated alternator, you don't have any rewiring to do. |
rfuerst911sc |
May 17 2010, 03:13 PM
Cool I will do that. I heard there was a PCA autocross today at the convention center...did you happen to go? I was signed up for it but we found out on Wednesday that my wife had to fly out of town on Sunday so I missed it. (IMG:style_emoticons/default/dry.gif) Sooner or later I'll get to run the 914 (IMG:style_emoticons/default/biggrin.gif) . |
bcheney |
May 22 2010, 08:51 AM
Thanks everyone for the help! Sorry for the delayed response....got busy this week at work.
Lo-Fi Version | Time is now: 4th June 2024 - 04:27 PM |
