> Wiper Delay question:, Installed Jeff's harnes and followed Andy's instructions:
Root_Werks
post May 17 2010, 09:26 AM
Village Idiot
Everything hooked up, I get the 3-wipes when the squirter is actuated, but no delay action when the wiper arm is moved "down".
It could be a bad relay?
I did:
Red/blk on the motor
blue to green (Switch to relay)
Grn from relay to motor (From the removed green now hooked to blue on relay)
Brn to ground on motor
Brown from switch to relay (this works fine).
Did I miss something? (IMG:style_emoticons/default/confused24.gif)
Replies(1 - 3)
r_towle
post May 17 2010, 09:35 AM
Custom Member
Turn key on.
Put wiper lever into delay position.
Check all the wires going to the relay for 12vdc.
Rich
jim_hoyland
post May 17 2010, 10:08 AM
Get that VIN ?
Did you break-off the tab that allows the selector into the delay position ? You end up with: Off, Low, Fast, and Delay
Root_Werks
post May 17 2010, 11:11 AM
Village Idiot
QUOTE(jim_hoyland @ May 17 2010, 09:08 AM) *
Yup, broke off the tab.
Hmm, Rich brings up an interesting point. I didn't really fiddle with things all that much. I did get power to the red/blk wire up to the relay, but didn't think to check the new blue wire.
I should also check ground, should be good, but you never know.
- Lo-Fi Version Time is now: 7th December 2025 - 04:23 AM
