| johannes |
May 20 2010, 12:50 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
What time is it ?
Now with the VDO precision of the seventies ... THE VDO REVS WATCH A Flash widget I made for the french club website. NEW DOWNLOADABLE VERSION for your PC desktop ... http://club914.fr/914watch.zip (IMG:style_emoticons/default/smile.gif) |
| poorsche914 |
May 20 2010, 06:15 AM
9fourteen ![]() ![]() ![]() ![]() Group: Members Posts: 3,151 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
very nice! Does it keep actual time? The pointer has only moved a couple spaces in the last several minutes.
| ottox914 |
May 20 2010, 06:30 AM
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Thats cool!
| johannes |
May 20 2010, 06:39 AM
very nice! Does it keep actual time? The pointer has only moved a couple spaces in the last several minutes. Yes, the needle shows hours. This is actual time from your computer. It's not supposed to be displayed at full screen but as a Widget in a website like this http://porsche914.fr-bb.com/index.htm ... French forum ... |
| Gint |
May 20 2010, 05:30 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Thanks Johnannes! That's awesome. I looked at a minute ago and it was almost the same time it was when I looked at it this morning at 05:32.
| tat2dphreak |
May 20 2010, 05:49 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
it's all wrong... at 6:48 it should be bouncing between 5 and 8 back and forth (IMG:style_emoticons/default/smile.gif)
j/k great job, really cool |
| poorsche914 |
May 20 2010, 05:54 PM
OK, I see how it works. Pretty cool how you have 9:14 as redline. (IMG:style_emoticons/default/piratenanner.gif)
| mipstien |
May 20 2010, 06:03 PM
Member ![]() ![]() Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
i want to read french now. google translate is only so good.
| 914four |
May 20 2010, 06:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States
Very cool!
| mpoffers |
May 21 2010, 10:18 AM
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-September 08 From: Portland, OR Member No.: 9,551 Region Association: Pacific Northwest |
That's very cool. Is there any way to run a small version directly on my desktop?
| bandjoey |
May 21 2010, 08:32 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Wish my tack was that bright in the car~..How do I make a widget on XP?
| underthetire |
May 21 2010, 09:07 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Very cool! You need to have the gas gauge show the month and the speedo show the day to go with it !
| johannes |
May 22 2010, 01:23 AM
That's very cool. Is there any way to run a small version directly on my desktop? Download this file http://club914.fr/914watch.zip Unzip and put the folder wherever you want This works on WinXP but should also work on Vista and Seven 1- Right click on your desktop of your computer and select Properties. 2- In the Display Properties box that appears select the Desktop tab and Customize Desktop… 3- In the new Desktop Items dialog select the "Web" tab then "New". 4- Now you can enter the path to "914watch.htm" file. Use the browse button to find the file. 5- At this time "Lock desktop items" button must be unchecked. 6- Apply. The item will then appears on your desktop background. 7- Click on the items border to move and resize the window however you like. 8- Once the item is in the right position you can return to the active desktop setup and check the "Lock desktop items" button Note for advanced users: You can change the size of the watch when editing the 914watch.htm file with the notepad. |
| Gustl |
May 22 2010, 06:22 AM
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,084 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
very cool thing !!! (IMG:style_emoticons/default/biggrin.gif)
thanks (IMG:style_emoticons/default/beerchug.gif) |
| mipstien |
May 22 2010, 07:24 AM
that is pretty cool. this would make an awesome windows 7 or vista gadget
| johannes |
May 22 2010, 07:44 AM
that is pretty cool. this would make an awesome windows 7 or vista gadget That seems very easy to do http://msdn.microsoft.com/en-us/magazine/cc163370.aspx But as I only have XP I won't be able to test it. So if anyone has time to buit it ... |
| Nürburg Nomad |
May 22 2010, 03:10 PM
914Rubber.com! ![]() ![]() Group: Members Posts: 296 Joined: 30-March 10 From: Buckeye State Member No.: 11,536 Region Association: Upper MidWest |
it's all wrong... at 6:48 it should be bouncing between 5 and 8 back and forth (IMG:style_emoticons/default/smile.gif) j/k great job, really cool Heh.. (IMG:style_emoticons/default/laugh.gif) funniest thing I've read all day... |
| mpoffers |
May 22 2010, 08:16 PM
That worked perfectly! I was trying to put the flash object directly on the desktop as a web object. Of course all I got was a white square. Using your html file did the trick.
THANKS!!! That's very cool. Is there any way to run a small version directly on my desktop? Download this file http://club914.fr/914watch.zip Unzip and put the folder wherever you want This works on WinXP but should also work on Vista and Seven 1- Right click on your desktop of your computer and select Properties. 2- In the Display Properties box that appears select the Desktop tab and Customize Desktop… 3- In the new Desktop Items dialog select the "Web" tab then "New". 4- Now you can enter the path to "914watch.htm" file. Use the browse button to find the file. 5- At this time "Lock desktop items" button must be unchecked. 6- Apply. The item will then appears on your desktop background. 7- Click on the items border to move and resize the window however you like. 8- Once the item is in the right position you can return to the active desktop setup and check the "Lock desktop items" button Note for advanced users: You can change the size of the watch when editing the 914watch.htm file with the notepad. |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:08 PM |
