Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
| McMark |
May 21 2010, 03:56 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
The cable is ~4'8" long as corresponds to ~2AWG cable.
The eyelet connection attaches to the starter. The connector has a ~8mm hole, and is soldered to the cable, then shrouded in ~21mm of heat shrink. The connector is not crimped. The battery attachment clamp is made from brass. It has a + symbol cast into it. The 'finger' which accepts the square portion of the pinch bolt has an edge to 'catch' the square and keep it from turning. The opposite 'finger' has enough clearance for the nut and a wrench. The clamp has a ~6mm bore for the wire to slip into. The ID of the clamp is tapered to match the battery post. The clamp is soldered to the cable. The pinch bolt had a provision for attaching the four big red wires from the main body harness. This 13mm x 13mm x 14mm block is drilled at tapped for a bolt (6mm x 1.00 x 12mm long). The factory original bolt has a 10mm head with a slot. The entire pinch bolt was machined from square stock. The threaded portion is 8mm x 1.25 x 29mm (~10mm left unthreaded). The entire pinch bolt assembly is made from mild steel. Attached image(s)
| IronHillRestorations |
May 21 2010, 04:44 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
I came up with #4 gauge Mark, 2 is larger. I couldn't find a part number for the pinch bolt, being able to get new ones would be nice.
| McMark |
May 21 2010, 05:47 PM
The bare copper cable is ~6.5mm diameter. All the sources I check specify that as a #2 cable. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 11th November 2026 - 06:48 AM |
