Idle Issues, '73 1.7L carbed |
buhs914 |
May 22 2010, 07:42 PM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
Ok well i recently put gas in my car and ran it for a while. When i started it up i was holding the clutch in as usual and the RPMs were rather high for idling.. as soon as i released the clutch the RPMs dropped back down to idle.. So that means the clutch is caught up on the accelerator.. but i recently checked it after installing the terry accelerator cable and it seemed fine.. What is the main cause of these two cables getting caught on one another? Links to other threads and pics would be much appreciated.
detoxcowboy |
May 22 2010, 08:24 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
I know nothing about carbs but the cables I do and they can get caught up on each other in the tunnel, I would if I were you open up and follow both cables that they are not in conflict with eachother or anything else in there.. And depressed the accelerator whilee looking that when it becomes taught it is not being blocked or otherwise.. Then do same with clutch, it sounds like they are laying in there in such a manner the the clutch cable is pulliong slightly on the accelorator cable maybe even lifting it ect..
underthetire |
May 22 2010, 10:28 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
After my last cable fiasco, I'm not sure the idle would be "rather" high, more like screaming OMG shut it down quick. I would look more at the pedal assembly. Not saying it's not possible the cables are twisted, just maybe inspect the little easier stuff first.
buhs914 |
May 23 2010, 12:14 AM
After my last cable fiasco, I'm not sure the idle would be "rather" high, more like screaming OMG shut it down quick. I would look more at the pedal assembly. Not saying it's not possible the cables are twisted, just maybe inspect the little easier stuff first. I'd have to agree with the screaming part. Tomorrow i'm going to check out the cables to be sure they are not the issue (hopefully that's it).. If it's not the issue i'll take pics and post them here for diagnosis. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:13 AM |
