> modified throttle cable, What have you done to improve pedal feel
pete-stevers
post May 23 2010, 12:34 PM
Shinee Side Up
I am thinking of using a different cable sys to improve pedal feel
your ideas,thoughts, quips, and insults are all welcome
Replies(1 - 6)
underthetire
post May 23 2010, 12:51 PM
My biggest improvement was.....replacing with a new stock one.
sean_v8_914
post May 23 2010, 12:52 PM
Chingon 601
clean the tube in teh tunel.
use a terry cable, dry
new gas pedal, no rubber molded around teh pivot
ditch the monster return springs
optimaize "pull angles.
carbs or FI?
pete-stevers
post May 23 2010, 11:00 PM
Shinee Side Up
it is a 3.0 cis six
i have replaced the cable ...no change
i am thinking of decreasing the throw, by increasing the lower throttle lever's length
on the arm mounted on the tranny( modified 911 part)
but i want a smooth pull, and it is currently notchy/sticky
sean_v8_914
post May 24 2010, 09:55 AM
Chingon 601
i understand your pursuit of smooth threottle feel, it is critical for smooth fast performance driving. notchy indicates a sticking point in teh system. isolate each segment of the system untill you find the "rub"
try the pedal by its self, then with a helper or a cleverly placed spring, feel just the cable.
then put a slight load on the bell crank and move it thu its motion....yadda, yadda, yadda..
realred914
post May 24 2010, 11:24 AM
Group: Retired Members
My V6 914 has a custom cable, a bicyle shifter cable from a long tandam bike. had to rig up the linkage at teh carborator (holley) but the bike cable worked great
pete-stevers
post May 26 2010, 12:55 PM
Shinee Side Up
QUOTE(realred914 @ May 24 2010, 10:24 AM) *
That is what i was thinking too, i bet a bicycle cable is better built than the current cable sys ....that is what i might just do
- Lo-Fi Version Time is now: 25th November 2026 - 05:01 PM
