| JRust |
May 25 2010, 05:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
Okay so I am putting a nice set of dual weber 40's on the LE. Going to get my break in miles done & drive it while I work on the FI stuff on the side. I get the basics of how to get them on. Was hoping someone could give me a nice step by step so I don't miss anything. Or put it on in the wrong order. I got the complete setup from Rich & he included everything needed except linkage which I picked up.
I allready installed the distributor & the intakes. I know I need to get my car to TDC & make sure my firing order is right. Okay lay it on me (IMG:style_emoticons/default/biggrin.gif) . In simple terms please (IMG:style_emoticons/default/blink.gif) |
| type2man |
May 25 2010, 05:49 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Bolting them on is pretty straight forward. The important part would be figuring out how much accelerator cable length you have and where it will be mounted and then you can work the linkage around it. Post up some pics of your carbs and the linkage, and I can help you out...
| jmill |
May 25 2010, 06:53 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Buy the weber tech manual. It's worth the money IMHO. It will walk you through the initial carb and linkage setup. Read it until you understand how every aspect of the carb is supposed to work. It makes it much easier.
| JRust |
May 25 2010, 07:33 PM
Bolting them on is pretty straight forward. The important part would be figuring out how much accelerator cable length you have and where it will be mounted and then you can work the linkage around it. Post up some pics of your carbs and the linkage, and I can help you out... Here are pics Attached image(s)
| SirAndy |
May 25 2010, 09:47 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,559 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Here are pics That fuel pump is going to drive you nuts ... (IMG:style_emoticons/default/shades.gif) Andy |
| JRust |
May 25 2010, 09:58 PM
Here are pics That fuel pump is going to drive you nuts ... (IMG:style_emoticons/default/shades.gif) Andy Tell me which one to get (IMG:style_emoticons/default/confused24.gif) |
| Kirmizi |
May 25 2010, 11:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Get a rotary, Carter IIRC, but I can't remember the part number. Probably do a forum search and find it easy enough though. I bought mine at a local FLAPS.
Waaaay quieter than that Facet pump! (IMG:style_emoticons/default/biggrin.gif) Mike |
| KaptKaos |
May 26 2010, 12:38 AM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
| Cevan |
May 26 2010, 05:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
| Gint |
May 26 2010, 05:47 AM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,111 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
You'd be a lot better off just getting the FI straightened out. You're going to waste a lot of time and money dickin with those carbs.
| dr914@autoatlanta.com |
May 26 2010, 07:54 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,250 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Don't do it and ruin this "special" car!!!!
Okay so I am putting a nice set of dual weber 40's on the LE. Going to get my break in miles done & drive it while I work on the FI stuff on the side. I get the basics of how to get them on. Was hoping someone could give me a nice step by step so I don't miss anything. Or put it on in the wrong order. I got the complete setup from Rich & he included everything needed except linkage which I picked up. I allready installed the distributor & the intakes. I know I need to get my car to TDC & make sure my firing order is right. Okay lay it on me (IMG:style_emoticons/default/biggrin.gif) . In simple terms please (IMG:style_emoticons/default/blink.gif) |
| tomeric914 |
May 26 2010, 08:33 AM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,325 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Tech manual:
http://www.cbperformance.com/catalog.asp?ProductID=4 You'll need a synchrometer as well: http://www.cbperformance.com/catalog.asp?ProductID=572 or http://www.pegasusautoracing.com/productde...s.asp?RecID=826 Prepare to become a meticulous expert in Webers if you want them to run right. Float setting is critical because it affects the transition between jets. Jetting is done via seat of your pants. What works on one motor may not work on your motor. Idle jets function at more than just idle. Transition to mains is at about 2500-3000 and to air correction jets at 4500-5000 with F11 emulsion tubes CLEAN EVERYTHING. Even new carbs need to be cleaned. All it takes is one little chunk to come loose and get stuck in one of the many jets. If you don't have the rain tray on your engine lid installed, make sure to have rain hats over the air filters. Water can get in through the top of the carbs if not sealed up. Rainwater is bad enough. Depending on what you use to wash your car, soapy water is bad news inside a Weber. I prefer the CBPerformance hex bar setup that integrates the pivot point into the air filter base (PN 3413 and 3414). Makes for a clean installation and no possibility for air to bypass the filter or water to get into the carb. http://www.cbperformance.com/catalog.asp?ProductID=547 Make sure the intakes are 100% sealed. Vacuum leaks are not your friend. Invest in earplugs for DE's. WOT is loud, even through a helmet. If you understand how Webers work, you'll enjoy them. If not, you won't. I have 2 cars with dual IDFs on them, one of which I have had Webers on for close to 15 years now. |
| computers4kids |
May 26 2010, 08:58 AM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Jamie,
Seems like you should be able to buy a complete "working" FI for a 74 off of someone, including the dizzy. I know your'e baffled, as well as others who looked at your car at the WCR, but I really think getting the FI right is the best for such a rare car as yours--even at the get-go.. A working "stock" FI is pretty much plugnplay, if you don't want to troubleshoot yours. I assume you have a different dizzy for the carbs? Good Luck, Mark |
| sean_v8_914 |
May 26 2010, 09:39 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
call me or PM. I'll try to help with your FI
| sean_v8_914 |
May 26 2010, 09:41 AM
dfghrehtr
Attached thumbnail(s) |
| sean_v8_914 |
May 26 2010, 09:42 AM
fxhfdth
| sean_v8_914 |
chfdzghd
| sean_v8_914 |
May 26 2010, 09:43 AM
bvngfxnfg
| sean_v8_914 |
May 26 2010, 09:44 AM
gcnbgfn
| sean_v8_914 |
gfngfdn
Lo-Fi Version | Time is now: 30th October 2026 - 10:59 PM |
