| detoxcowboy |
May 26 2010, 11:10 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Is there a way to replace the crankshaft seal on the impeller end without a special vw tool? is there another tool I could use? and assist appreciated..
| realred914 |
May 26 2010, 11:34 AM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Is there a way to replace the crankshaft seal on the impeller end without a special vw tool? is there another tool I could use? and assist appreciated.. a bearing seal puller helps it is a axle looking thing that has a curved sickle shaped blade on a handle, it can be used to pull the old seal out, I had to modify the one I use by moving the handle to get the right angle as the shaft that sticks out of the motor gets in the way of the tool. I have laos used a center punch needle pliers and screw drivers to get them out, just dont bugger up the case when doing this. then use appropiate sized sockets or pipes to be used place the near seal in with gentle blows form a mallet, it is very important to get it strights. i believe I have also may have used the fan flange and some sockets or pipe sections and used the flange to press it home by screwing down the flange. the new seal must go in perfectly flat and square to seal right. have fun |
| detoxcowboy |
May 26 2010, 11:41 AM
Thanks for the seal advice, but I am contronted with the hub itself and how do you pull that off, I have taken the nut off and am ready to pull it but do not want to destroy anything by ignorant force.. ..
| McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
If you want to use the real tool, let me know. I'd need it back ASAP, but I'm not against lending it out. PM me if interested.
| detoxcowboy |
May 26 2010, 11:49 AM
Mc mark, I just may take you up on that, but the hub removal is the main issue and that tool looks like a c shaped plate according to the fsm, as far as the seal I have the seal puller but not the installer. I have 2 new seals, so If I bugger one up, I will pm you..
| Jake Raby |
May 26 2010, 12:08 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
The hub has a #2 morse taper on it that affixes it to the crankshaft, they can be difficult to remove.. a steering wheel puller is generally the most general tool used for this.
Once the hub is pulled the seal easily is removed, you can use a drywall screw inserted in to the seal to pull it from the case. Note that there is an O ring between the hub and the crank- replace it. |
| ClayPerrine |
May 26 2010, 12:15 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
For you dyi guys.. go to Harbor freight and get a "bolt grip puller" set. It can be used to pull the hub. Also, when you put it back, take a brass hammer (also available at harbor freight) and give it a good whack before installing the bolt in the crank center. And use a torque wrench to tighten the bolt. |
| detoxcowboy |
May 26 2010, 12:26 PM
Perfect and fast advice, thank you 914 world!
| Cap'n Krusty |
May 26 2010, 01:36 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
2 sturdy old fashioned "church keys" substitute well for the factory tool. The thicker the better, and it's best to use the hardest ones you can find. Be sure to use bolts other than the 3 you want to use for reinstalling the fan. The ends are apt to get chingered up. As others have pointed out, be sure to replace the o-ring as well as the seal. It'll leak if you don't.
The Cap'n |
| type47 |
May 26 2010, 05:57 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Look at my Mar 12 2010 entry in my blog (Type47's blog) or
| detoxcowboy |
May 26 2010, 07:22 PM
2 sturdy old fashioned "church keys" substitute well for the factory tool. The thicker the better, and it's best to use the hardest ones you can find. Be sure to use bolts other than the 3 you want to use for reinstalling the fan. The ends are apt to get chingered up. As others have pointed out, be sure to replace the o-ring as well as the seal. It'll leak if you don't. The Cap'n That solved it Cap'n even after I took a steering wheel puller on loan, could not get the puller to line up any whihc way, I used 3 large thick construction washers, popped of w/ an instant .. When Is you book comming out? Or no book and I am thinking I read what I did not read?/ |
Lo-Fi Version | Time is now: 30th April 2026 - 05:24 AM |
