| Mikey914 |
May 30 2010, 08:03 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,775 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
This is a rebuild kit for the early air box in the front. The "flappers" in the lower section (that most are long gone), the seal between the two sections o fthe unit (with a self adhesive back to hold it in place while you screw these together, and the rubber edge protector between the box and the vent at the cowl.
How can you tell if yours is early or late? Do you hae a grill? If so yours is late. $15 + shipping for all, and of course I do combine. |
| Mikey914 |
May 31 2010, 11:37 AM
Pictures added -
These make it a nice tight fit for the air diverters Attached thumbnail(s) Attached image(s)
| Mikey914 |
Before
Attached thumbnail(s) |
| bandjoey |
May 31 2010, 12:06 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Hi Mark. Can you or someone post some more detailed into on years for early and late, or some pictures of what to look for? The flapper you show is probably inside and not visible to the eye. What's 'grill'? I have the air openings cut in front of the windshield, but nothing except the plastic box when looking down into the hole.
Thanks |
| Mikey914 |
May 31 2010, 12:15 PM
Early Box top Seal and Main Box seal with self adhesive back.
| Mikey914 |
May 31 2010, 12:16 PM
Early rubber top isolator
| Mikey914 |
May 31 2010, 12:23 PM
You have an early.
Late shown. You can see what I mean about the "grill" Attached thumbnail(s) |
| McMark |
May 31 2010, 12:32 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
These work for all years and make rebuilding your air box REALLY easy. These are the flappers that keep unwanted 'fresh' air from flowing into the cabin.
Lo-Fi Version | Time is now: 14th April 2026 - 04:54 PM |
