Stupid question - How to remove seats? |
KaptKaos |
Jun 4 2010, 11:07 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I know you slide them forward, and I think that there is a clip or something under the rail or something.
Hints/tips/tricks? |
underthetire |
Jun 4 2010, 11:09 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
steveherman |
Jun 5 2010, 12:56 AM
Member Group: Members Posts: 380 Joined: 12-September 09 From: Kissimmee Florida Member No.: 10,799 Region Association: South East States |
I just slide them all the way back.
then stick a large flat head screwdriver in as far as possible in the rail opposite of the handle. then with a little more force then normal slide it forward and keep going until it comes off the track. |
VaccaRabite |
Jun 5 2010, 06:13 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Took me a long time to figure it out the first time I tried. Zach |
nsr-jamie |
Jun 5 2010, 08:54 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
You don't even need tools, I removed both my seats last week with my hands...slide it to the front and under the seat on the rail of the side with the adjuster handle there is this little stopper tab. Just push and hold that up towards the roof and with some luck your seats should just slide of the rails with no problems. Its pretty easy. You may get a bit dirty and watch you don't pinch your finger in there.
detoxcowboy |
Jun 5 2010, 12:42 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
You only needs your fingers push the clip under the rail up as you push the seat foward until it passes the placement lock postion holes,..
The harder part is lining the rails up to put them back in.. |
steveherman |
Jun 5 2010, 02:38 PM
You don't even need tools, I removed both my seats last week with my hands...slide it to the front and under the seat on the rail of the side with the adjuster handle there is this little stopper tab. Just push and hold that up towards the roof and with some luck your seats should just slide of the rails with no problems. Its pretty easy. You may get a bit dirty and watch you don't pinch your finger in there. I pinched/sliced my finger wide open ONCE!!! GOD DAMN did it hurt like a mf'er!!! I will never stick my finger in there again. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:48 AM |
