over analyzing trunk spring rollers, plastic, brass, alu? |
dem |
Jun 5 2010, 07:37 AM
Rusty Member Group: Members Posts: 147 Joined: 7-February 10 From: Cupertino, CA Member No.: 11,334 Region Association: Northern California |
Mine are cracked. Looks like there are 3 choices, all pretty much around the same price!
Do I care? I'm almost tempted just to go with plastic, since that is what the factory used and as far as I can tell they have survived 37 years. If metal is reaaaaaaaly better, do I care about aluminum or brass? Let's see some passionate, religious debate about my trunk rollers. Choices, they paralyze me! (IMG:http://www.914world.com/bbs2/uploads_offsite/www.haphazard.com-11334-1275745074.1.jpg) |
underthetire |
Jun 5 2010, 07:56 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
When do you need/want them by ? The brass ones will be weeks before they show up, but probably outlive the car. Aluminum can seize up if not properly lubed. Delrin would make the best rollers IMO, but don't know if those are plastic or delrin.
Katmanken |
Jun 5 2010, 03:34 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
They are all the aftermarket design and have a bigger rotating bearing surface which is good.
My choice would be: Drop the aluminum as a choice. Aluminum makes a crappy bearing and galls. Now it's down to brass and plastic..... If the brass is an oillite bearing, I'd go with that. No oillite, then you need grease so switch to lubricious plastic. Lubricious plastic needs no oiling and in order of choice: 1. Delrin, and 2 , Nylon. Actually delrin makes a nice slick forever bearing that needs no lube, never wears, etc and may trump oilite which needs an occcasional oiling.... |
detoxcowboy |
Jun 5 2010, 05:25 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
pelican parts carries delrin..
IronHillRestorations |
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I kind of like the brass ones, but KWales makes a good point on the plastic. I don't know how you'd find out the lubrocity of the plastic though.
lionel_atlanta is Automobile Atlanta |
dem |
Jun 5 2010, 05:52 PM
pelican parts carries delrin.. oo, another option.. although Pelican calls it "delrin-like" (IMG:http://www.914world.com/bbs2/uploads_offsite/www.haphazard.com-11334-1275781952.1.jpg) |
toon1 |
Jun 6 2010, 07:47 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
OR you can use the camp 914 trunk shocks. they work great.
I have a set of brass rollers that I am not going to use. PM me if interesterd. Keith |
Lo-Fi Version | Time is now: 10th June 2024 - 06:46 AM |
