This Stuff Works!, Drain Tube Stunt Double |
EdwardBlume |
Jun 6 2010, 02:27 AM
Someone said Home Depot, and they would be right... works better than new....
Not cheap, but then again I have some left over... (IMG:style_emoticons/default/idea.gif) Attached image(s) |
914Sixer |
Jun 6 2010, 06:20 AM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You can always offer the members some pre-cut pieces and recoup your cost. Do not for get they will also work for the front air box drains.
rick 918-S |
Jun 6 2010, 08:28 AM
Hey nice rack! -Celette Group: Members Posts: 20,506 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
That looks very stock in the photos!
Katmanken |
Jun 6 2010, 09:45 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
I've never seen those tubes looking clean and shiney...
Mine look like dirty junk |
pete-stevers |
Jun 6 2010, 10:44 AM
saved from fire! Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
then there is the other solution...don't drive in the rain...
problem is ....i am not driving even when it is sunny (IMG:style_emoticons/default/headbang.gif) |
sean_v8_914 |
Jun 6 2010, 01:15 PM
HD racing delivers!
Bruce Stone was the first to discover the HD racing drain tubes. sprinkler hose, right? the ribs are spiral, unlike the concentric ribs of teh OEM drain tubes |
EdwardBlume |
Jun 6 2010, 01:59 PM
Yes. Exactly, they are spiral instead of parallel. Seem to be strong and fit perfectly inside and out. The downside is that the investment from HD is $22 including tax. I have 3 pairs sitting here.
gothspeed |
Mar 23 2012, 11:10 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I went to HD and could not find the stuff noted above (IMG:style_emoticons/default/sad.gif) ......... it may be NLA as the employees there could not even find the sku # in the HD computer (tried 2 HDs here in Southern Califonia). In such case;
I used 5034K18 from mc master carr and the material construction was perfect for this application. Nice interference fit onto the plastic drain nipples (no hose clamps needed) and it sealed perfectly into the factory grommets below. It also holds its cylindrical shape well as it has a 1/8" wall. IMO it looks cleaner and works better than what the factory used (IMG:style_emoticons/default/smile.gif)!!! The finish is smooth and will not trap debris the way my factory corrugated versions did. Not for those OEM restorations though. 5034K18 Abrasion-Resistant Blk Neoprene Rubber Tubing 7/8" ID, 1-1/8" OD, 1/8" Wall Thk http://www.mcmaster.com/#catalog/118/140/=gsfrkc Note: O.D. of the 914 drain nipples was about .941" ........... the mcmaster hose I.D. is .875" .......... makes for a nice snug clampless fit (IMG:style_emoticons/default/smile.gif) |
TheCabinetmaker |
Mar 23 2012, 11:21 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I've never looked for it but remember hearing dishwasher drain hose is very close too
zonedoubt |
Mar 23 2012, 01:45 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
type47 |
Mar 23 2012, 02:04 PM
Post a SKU or UPC number off the receipt if you still have the receipt, that way you can check stock in a store on their computer
kconway |
Mar 23 2012, 06:23 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm in Long Beach and have a crapload left over. If anyone local is interested for a six pack I will set you up with what you need for the whole car.
Kev |
Black914_4 |
Mar 23 2012, 06:48 PM
Member Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
I'd be interested in a set. I broke one of mine putting the battery in.
jim_hoyland |
Mar 23 2012, 06:55 PM
Get that VIN ? Group: Members Posts: 9,329 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The hose is called Becker Irrigation Hose. I saw I at HD in an obscure location around the garden supplies. Not in plain sight.....
Lo-Fi Version | Time is now: 17th June 2024 - 05:01 PM |
