differences between 1.7L 70/71 and 73 wiring harness |
project-914 |
Jun 8 2010, 09:37 AM
Member Group: Members Posts: 181 Joined: 2-August 06 From: Oklahoma Member No.: 6,571 |
Hey, there is a good deal on a 70/71 wiring harness and I have a 73 that I just need to run. Will this work? It's a 1.7L
What are the differences? thanks |
ClayPerrine |
Jun 8 2010, 11:08 AM
Life's been good to me so far..... Group: Admin Posts: 15,521 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The 70-71 had the heater blower mounted on the engine. The 73+ had the heater blower mounted on the body, so the later harness has a jumper to loop the heater fan power back to the relay board.
Now if you have a 74-75 1.8L, there is an addition to the harness to support the L-Jet. |
SLITS |
Jun 8 2010, 12:10 PM
component plug location is slightly different, but you might be able to make it work with a little effort.
JeffBowlsby |
Jun 8 2010, 01:10 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Which harness are you asking about? There are differences in all of these between the model years you mention.
Main chassis harness? Fuel injection harness? Ignition harness? The Alternator harnesses are all the same between the different model years. You can make any harness work on any 914, but you may need to make changes to certain connectors, run extra wires or other mods. The wiring gages may also be different from year to year for certain circuits. Best advice is to get the exact same model year harness for your car and avoid complications. |
SirAndy |
Jun 8 2010, 01:24 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Which harness are you asking about? There are differences in all of these between the model years you mention. Main chassis harness? Fuel injection harness? Ignition harness? (IMG:style_emoticons/default/agree.gif) The main chassis harness will not fit without MAJOR reworking of pretty much all electrical components. BTDT. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
project-914 |
Jun 8 2010, 02:07 PM
Which harness are you asking about? There are differences in all of these between the model years you mention. Main chassis harness? Fuel injection harness? Ignition harness? (IMG:style_emoticons/default/agree.gif) The main chassis harness will not fit without MAJOR reworking of pretty much all electrical components. BTDT. (IMG:style_emoticons/default/popcorn[1].gif) Andy that's what I needed to hear. I am ok with leaving out "seatbelt fasten" lights but no with adding wires and hacking into it. with that being said? anybody have a 73 chassis harness? (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:04 AM |
