How to plug vapor system?, Until I can source a charcoal canister |
narino |
Jun 8 2010, 03:31 PM
Member Group: Members Posts: 231 Joined: 14-August 07 From: Los Angeles, CA Member No.: 8,001 Region Association: None |
So I've been getting a lot of 'smell' in the car. After some digging here I figured I'd start with plugging up the vapor system. When I got my 72 she never had the charcoal canister so I'm just trying to find the easiest solution till i can source a canister and run the lines correctly.
Pat I'm going to borrow your pic as I dont' have one of my car readily available. In the pic can i plug the expansion tank at that location? Also, where does the the other hose i've marked lead to? TIA (IMG:style_emoticons/default/beer.gif) |
underthetire |
Jun 8 2010, 03:38 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Want the smell gone, replace the seal in the gas cap.
GeorgeRud |
Jun 8 2010, 03:40 PM
The big hose on the passenger's side simply dumps onto the ground. I would leave the small one disconnected and simply let it vent for the time being. If you don't fill your tank to the top, you probably won't have a real problem.
You might try putting an ad up in the parts wanted section. I imagine that some of the folks that have converted their cars into track cars may have some of these tanks available. If not, Auto Atlanta or one of the other used parts dealers should be able to hook you up. One does forget how much gasoline smell is present as most of today's cars have sealed systems (with EFI and the other vapor recovery devices). |
narino |
Jun 8 2010, 03:42 PM
Jeff - Good call, will do.
George - Thanks for the info. At the moment the expansion tank has no tubes hooked up to it. So it breaths right into the front trunk. I'm running half a tank and the smell is enough to bother. Is plugging it at that location ok, or would there be issue with pressure building up in the tank? |
70_914 |
Jun 8 2010, 03:49 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
Jeff - Good call, will do. George - Thanks for the info. At the moment the expansion tank has no tubes hooked up to it. So it breaths right into the front trunk. I'm running half a tank and the smell is enough to bother. Is plugging it at that location ok, or would there be issue with pressure building up in the tank? Electric fuel pump and sealed tank = no fuel to engine. The amount of fuel coming out will need to be replaced with air, or a vacuum will build up. Found out the hard way after retrofitting an early tank into my later bug. I could drive 25 miles and then the car would die. Pressure would build up when the car was sitting, just like gas cans for your lawn mower. |
JeffBowlsby |
Jun 8 2010, 04:32 PM
914 Wiring Harnesses Group: Members Posts: 8,534 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
If its the plastic canister (not the metal one, new activated charcoal can be installed cheaply. Google is your friend for suppliers.
Attached image(s) |
realred914 |
Jun 8 2010, 05:58 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
make sure your hoses are clean before hooking it up, make sure the hoses in the wheel wells are not broken. road debries can get sucked into the lines and the suction line feeds the intake manifold AFTER the air filter. you dont want unfiltered road debreis!!!!
narino |
Jun 8 2010, 06:18 PM
realred- thanks for the heads up.
Though I'm still diggin on how I'm going to hook this up to a carbed motor. Would I need to drill the top to the air filter to connect there? |
Lo-Fi Version | Time is now: 10th June 2024 - 01:05 PM |
