Bulbs, All the bulbs on a 914 |
Teknon |
Jun 13 2010, 04:02 PM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
Do we have a list of the light bulbs that are used in our cars?
Somebody must have categorize it im sure. I can not find it, in any source I have. I'm especially concerned with the truck light. |
underthetire |
Jun 13 2010, 04:09 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
http://www.sylvania.com/ConsumerProducts/A...LRG-Results.htm
Think the trunk was the same as the license lamp. |
JeffBowlsby |
Jun 13 2010, 04:32 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Here is my list, mostly complete:
Attached thumbnail(s) |
underthetire |
Jun 13 2010, 04:46 PM
underthetire |
Jun 13 2010, 04:54 PM
Although, I do see an error or two, the 1157's and 1156's cross over the same, 1156,and 1157's. Just FYI.
JeffBowlsby |
Jun 13 2010, 04:55 PM
This and other tech references can be found here:
http://bowlsby.net/914/Classic/TechNotebook.htm (IMG:style_emoticons/default/biggrin.gif) |
Teknon |
Jun 13 2010, 05:37 PM
WOW
Incredible, thanks so much! |
Tom_T |
Jun 14 2010, 02:28 AM
This and other tech references can be found here: http://bowlsby.net/914/Classic/TechNotebook.htm (IMG:style_emoticons/default/biggrin.gif) Also in your owners manual (IMG:style_emoticons/default/biggrin.gif) IMHO use caution to not use larger wattage bulbs than listed in the owners manual, because at least they'll melt/warp your plastic lenses/housings, at worst may be fire hazard. Many parts suppliers will try to sell you "bigger" bulbs cuz they're supposedly better or brighter, when in fact they just don't have/carry the proper ones! |
buhs914 |
Jun 14 2010, 03:17 AM
Not So Newbie Group: Members Posts: 331 Joined: 16-June 09 From: Buckeye, AZ Member No.: 10,478 Region Association: Southwest Region |
This and other tech references can be found here: http://bowlsby.net/914/Classic/TechNotebook.htm (IMG:style_emoticons/default/biggrin.gif) Also in your owners manual (IMG:style_emoticons/default/biggrin.gif) IMHO use caution to not use larger wattage bulbs than listed in the owners manual, because at least they'll melt/warp your plastic lenses/housings, at worst may be fire hazard. Many parts suppliers will try to sell you "bigger" bulbs cuz they're supposedly better or brighter, when in fact they just don't have/carry the proper ones! or you could get the LED replacements and have lower heat and won't have to worry about warping! |
type47 |
Jun 14 2010, 05:31 AM
Auto Atlanta catalog has a good list of bulbs too.
McMark |
Jun 14 2010, 10:35 PM
Another tid-bit, having incorrect resistances will cause your turn signal indicators (in the tach) to both flash, instead or just the left or just the right. Using the correct bulbs and with clean connectors and grounds should make the indicators work correctly.
Lo-Fi Version | Time is now: 2nd June 2024 - 02:14 AM |
