Oil Filter question, 3.6 six conversion |
East coaster |
Apr 6 2004, 03:01 PM
Senior Member Group: Members Posts: 1,687 Joined: 28-March 03 From: Brigantine, NJ Member No.: 487 Region Association: None |
I wanted to order some oil filters for my six conversion, but I'm not sure what filter to order? It will be a 3.6 conversion running a stock 914-6 oil tank. Is there a particular year or model that would be best??? Can I just order a stock 914-6 filter?? I was worried about the flow w/ a stock 6 filter and the higher volume pump in the 3.6.
ArtechnikA |
Apr 6 2004, 03:15 PM
QUOTE(East coaster @ Apr 6 2004, 01:01 PM) ... I'm not sure what filter to order? It will be a 3.6 conversion running a stock 914-6 oil tank. Is there a particular year or model that would be best??? i would very seriously consider at least using the 73+ oil filter console and the newer type filters. other than that, i don't know the details of what the big-engine conversion guys have done to handle the flow, so i'll be watching this thread and trying to learn too ... |
siverson |
Apr 6 2004, 03:17 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I welded on the slightly larger fitting (sorry, don't remember the dimensions), that let you use the bigger 930 filter. Oil filter part #: 930.107.764.01
-Seve |
East coaster |
Apr 7 2004, 04:36 AM
Steve, You welded on a larger fitting to what? The oil filter casting??
siverson |
Apr 8 2004, 06:33 PM
Ooops, sorry, I just took a look at it to remember what I did.
I use a Vellios tank which is threaded to accept a number of different oil filter adapters. So the male-male adapter that is screwed into my tank (not welded as I had thought) is slightly larger for the 930 oil filter. Make sense? -Steve |
Lo-Fi Version | Time is now: 1st June 2024 - 12:32 PM |
