E-Brake light continues to Blink, Cleaned the switch..still blinking |
Vysoc |
Jun 18 2010, 07:24 AM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Hello,
Working on something else the other day and I noticed that when I put my E-Brake in the down position and it should stop blinking after start up, that it continues to blink, I took the switch out checked the connection and cleaned the connection, replaced and still blinks. Do these switches go bad? Where is the path of the wires from the switch to the left guage, I assume it runs under the seat brace to the console and up into the dash, I should check the connection to the guage from the switch at the E-Brake next? Any ideas? Thank you, Vysoc (IMG:style_emoticons/default/idea.gif) |
flipb |
Jun 18 2010, 07:49 AM
Senior Member Group: Members Posts: 1,724 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Sounds like you need to press the reset button on the master cylinder.
Vysoc |
Jun 18 2010, 07:58 AM
nsr-jamie |
Jun 18 2010, 08:29 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
It would be nice if somebody had a picture of the acutal reset switch too if possible.
flipb |
Jun 18 2010, 08:35 AM
You need to reach the master cylinder. There are photos of the switch somewheres on 914world, try search.
It's easiest with the car off the ground, but I managed to reset mine while parked by turning the wheels to the right, reaching behind the left front wheel with a flashlight and finding the button. Expect to get your hands dirty/scraped using this method - the other risk is of accidentally pulling the wire off the spade connector that feeds the brake light flasher. Re-connecting that with the car on the ground is a severe PITA. (IMG:style_emoticons/default/smile.gif) |
flipb |
Jun 18 2010, 08:40 AM
Here's a photo of my car, using the "reach-around" method to hit the reset button. (IMG:http://www.914world.com/bbs2/uploads/post-10752-1271383421.jpg)
The white plastic surrounds the metal button. On the left side, hard to see in this pic, is the male spade connector to which the wire in the foreground was connected... before I accidentally yanked it off. |
McMark |
Jun 18 2010, 10:44 AM
OMG! It's been 10 years of me ranting about this over and over and over again. Not all brake light switches have the reset button.
Joe Ricard |
Jun 18 2010, 10:57 AM
Mark is right, I did have a M/C that did not have a button. I never seen a metal button. All mine have been plastic.
zonedoubt |
Jun 18 2010, 02:11 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
For those without the button, unscrew the switch, then screw it back in. Worked for me.
Vysoc |
Jun 21 2010, 10:55 AM
Thanks, to all for the great suggestions.
Monday is my day off and day to work on the car. Jacked front up removed front left wheel. PO changed the MC to 19mm, no reset button, so I simply unhooked the connection. Cycled the ignition on, light was blinking put E-Brake down, light quit blinking. Turned switch off, reconnected wire to MC, turned ignition switch, light began blinking, put E-Brake down, light quit blinking. I did check before I started and the E-Brake was still blinking in engaged and unengaged E-Brake positions so, I think that is it......I hope Oh yeah...before I submitted this I just went out and actually started the car up with E-Brake engaged, light blinking, E-Brake disengaged....light quit blinking. I'm going to take this as a mini victory (IMG:style_emoticons/default/w00t.gif) Thanks to all for the great information. Vysoc |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:58 AM |
