Rear shock options, What are you running and what do you think? |
ottox914 |
Jun 23 2010, 10:01 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Along with getting the turbo 914 motor back together, I'm thinking of different rear shocks. Currently running Koni sports F and R, and with the car lowered I am quite certain I am bottoming the rear ones out.
I did the zip tie on the shaft thing, the front insert has 1/8" or less space before it gets to the bump stop, so good there. The back ones are up against the bumpstop, and I have a sharp "CRACK" sound when hitting just the right bump at just the right speed. Never on course at an autocross, but often on the highway going to and from events. Uneven expansion joints can be murder on the ears. So thinking of some shorter shock for the back. Whats anyone else running? There seem to be lots more choices for shocks with "eyes" on the top and bottom, than those like the stockers with an eye on the bottom and a shaft/nut on the top. If you've got a 2-eye set up installed, add a few pics, please. |
ChrisFoley |
Jun 24 2010, 09:11 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I switched to Ohlins LMJ dual adjustable rear shocks this season.
So far so good. At Lime Rock last weekend I made one adjustment to both bump and rebound and had a much better feeling in the corners right away. I went with 7" stroke. With my ride height and other mods the shock is about at the center of the stroke at rest. |
ottox914 |
Jun 24 2010, 09:43 PM
Is Chris the only one to run a non "stock" shock?
Those look like amazing pieces of work. Where did you get yours and how much? Anc, can you show how you did the top mount, or is that top secret? |
nsr-jamie |
Jun 25 2010, 05:25 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Wow! That is cool !!! How about Penske? I have one on my motorcycle that they custom made for me and its incredible and fully rebuildable too....you could try to contact them...you would probably be the first 914 guy with Penske shocks...incredible quality, I like them better than Ohlins...but I only have experience with light weight 2 stroke racing motorcycles..cars are totally different. Cheers
ChrisFoley |
Jun 25 2010, 06:41 AM
Is Chris the only one to run a non "stock" shock? Those look like amazing pieces of work. Where did you get yours and how much? Anc, can you show how you did the top mount, or is that top secret? I had them customized for 914 use by a dealer in New Hampshire. Its an item I'll be adding to my website soon. Thorshammer (Erik Madsen) recommended them as being better quality and better damping characteristics than Peske, etc. My shock towers are not stock so I made special mounting brackets, but you would need something similar. I'm not sure I took pictures. Something very close to what's needed is available from Smart Racing Products (and Rebel Racing I think) but fairly expensive. The lower mount is a custom piece as well, that I made from an oem shock bolt. Price is in the range of $1400 for the pair, including customization and shock dyno report. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:02 PM |
