Oil change, valve and clutch adjustment, under 2 hours |
Cevan |
Jul 2 2010, 06:09 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I put another 500+ miles on my new engine and it was time for an oil and filter change and valve adjustment. I also pulled the sump cover for inspection and adjusted my clutch cable. None of the valves ended up needing an adjustment. I'm good for another 3000 miles. (IMG:style_emoticons/default/aktion035.gif)
It took me about an hour and 45 minutes start to finish. Not bad I think for a non-mechanic. (IMG:style_emoticons/default/beerchug.gif) |
rwilner |
Jul 2 2010, 07:25 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
why would you post something like this, and risk angering the 914 gods
TheCabinetmaker |
Jul 3 2010, 06:38 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What took ya so long?LOL
914rat |
Jul 3 2010, 09:17 AM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
why would you post something like this, and risk angering the 914 gods Yea, do you really want them to know you are not on jackstands?Hell I park mine over a lift just in case they are watching.When it's running that is. (IMG:style_emoticons/default/happy11.gif) |
realred914 |
Jul 3 2010, 10:04 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
new motor, I'd probably recheck them valves again before another 3000 miles (more like 500 again) to be on teh safe side. if they are still stable, then i say your golden. do a second oil change then also. that first round of break in oil did not get all drained out the first oil change, and it is surely full of residue. a second oil change will remove a lot more of that initial break in oil and grit.
have fun with the new motor, who built it? what compresiion ratio, valve sizes, cam? me i am thinking of a bigger motor asap as mine is bit the dust. is yours running stock d-jet ok? just want to get some ideeas if you can be of any help. thanks! |
Cevan |
Jul 3 2010, 10:44 AM
new motor, I'd probably recheck them valves again before another 3000 miles (more like 500 again) to be on teh safe side. if they are still stable, then i say your golden. do a second oil change then also. that first round of break in oil did not get all drained out the first oil change, and it is surely full of residue. a second oil change will remove a lot more of that initial break in oil and grit. have fun with the new motor, who built it? what compresiion ratio, valve sizes, cam? me i am thinking of a bigger motor asap as mine is bit the dust. is yours running stock d-jet ok? just want to get some ideeas if you can be of any help. thanks! I didn't mean my post to be boastful in any way. I was just psyched that I'm getting more proficient with this car stuff. As for the motor, I did a cam breakin and then changed the oil and filter and adjusted the valves. Then I drove it for about 125 miles and did another oil/filter change and valve adjustment. Then I went another 550 miles and did another oil/filter change and valve adjustment. My engine build link is in my signature. It's a 2056 with rebuilt stock 2.0 heads, a Raby 9050 cam, 9:1 compression, 40mm IDFs. Fun fun fun. |
Elliot Cannon |
Jul 3 2010, 12:59 PM
You obviously forgot to tighten something. (IMG:style_emoticons/default/happy11.gif) You might want to pull the valve covers off again. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/lol-2.gif) I'm just sayin'.
HAM Inc |
Jul 3 2010, 03:50 PM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE why would you post something like this, and risk angering the 914 gods Chris appeased the 914 gods by having his heads rebuilt with the good stuff and using quality engine parts while paying close attention to his build! The gods are tough, but they do respond favorably when we do things right! BTW, Chris' heads were probably the nicest 2.0 914 heads I have ever seen! Glad to hear the new engine turned out great for you Chris! |
Cevan |
Jul 3 2010, 04:43 PM
Thanks Len. My head temps are lower than the stock 2.0 by 25-50 degrees, so hopefully those heads stay nice. Definitely happy with the 2056. (IMG:style_emoticons/default/driving.gif)
And to think that engine came out of a parts car. (IMG:style_emoticons/default/beerchug.gif) |
HAM Inc |
Jul 4 2010, 01:30 PM
QUOTE Thanks Len. My head temps are lower than the stock 2.0 by 25-50 degrees Chris that would be the 9550 cam at work. It lets the exhaust breath, and take advantage of the nice ex ports those heads come with. Glad you like your 2056. Just think of the new car reviews the 914 would have gotten back in the day if it had come std with that engine! |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:54 AM |
