Replacement Fire Walls, early years |
obscurity |
Jul 5 2010, 08:41 AM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
I know AA and Restoration Design sell late model fire walls is there a source of early firewalls (or at least the bottom section)?
I have 1- 3 inches of rot along the entire bottom edge but the rest looks pretty good. Aside from the shift linkage what are the other differences? |
realred914 |
Jul 5 2010, 09:41 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I know AA and Restoration Design sell late model fire walls is there a source of early firewalls (or at least the bottom section)? I have 1- 3 inches of rot along the entire bottom edge but the rest looks pretty good. Aside from the shift linkage what are the other differences? Call rich, High Perfromance House in Calif. 650 364-6234 he has many 914 he has parted out, he cuts and saves body panels, he might have a good used one for you good luck |
dr914@autoatlanta.com |
Jul 5 2010, 10:05 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The repair piece I originally designed was only for the late model as there were more of those out there and the fact that the early and late were the same except for the early vs late shift console. We when repairing the early cars, just remove the early console and weld it into the late repair panel. Since it is so tough, it rarely rusts through and is readily reusable.
I know AA and Restoration Design sell late model fire walls is there a source of early firewalls (or at least the bottom section)? I have 1- 3 inches of rot along the entire bottom edge but the rest looks pretty good. Aside from the shift linkage what are the other differences? |
Tom_T |
Jul 5 2010, 12:41 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Also the late upper firewalls at the top, sides & lower just above the engine tray lip have some clips welded on to hold the firewall pad, which the earlier 914s didn't have.
Lo-Fi Version | Time is now: 2nd June 2024 - 02:38 AM |
