Newbie trans conversion question |
moparrob |
Jul 5 2010, 10:51 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
So I am doing a 914-6 conversion, which will in part consist of converting my trans from a 914/901 side shifter (1974) which is a push-type throwout arm and bearing - to a 911/901 based side shifter with a pull-type throwout arm. As you know, the 911/901 is a tail shifter, never came as a side shifter, and has the throwout arm pivot point in a different location than the 914. So here is my question:
Is it possible to take a (1970) 911/901 case (which has the correct pivot location) and convert it to a side shifter by using all the 'good' parts off of my 914 side shifter and installing them in the 911 case? In other words, can I disassemble my 914 box, install all the guts, the side shifter mechanism, and the later tail cone onto an early 911 case? Are there any further modifications which need to be performed? Thanks in advance for any help you may be able to offer. Rob |
pcar916 |
Jul 6 2010, 07:54 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
I've never tried that but the gasket set's are the same except that the side shift console seals aren't included in the 911 set. But i have another consideration as well since you are converting to a six with more horsepower.
Even if the side shift console will fit into the access hole properly and the other parts fit, the 901 case is weaker than the 914 case. The 914 case has far more (and deeper) external webbing both on the case proper and on the side cover. I suspect you can find a 914 case somewhere for not much cash. You have to buy another gasket set and set up the differential in a new case regardless. I have a friend with an already converted 914 case that I think he still has. That said, I have run a 3.6L motor and the older (225mm) push style clutch since 1994 with no problems whatsoever. Good luck! |
IronHillRestorations |
Jul 6 2010, 08:06 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If you use a 911 transmission you'll have to have the ring and pinion flipped, and that's expensive.
9 times out of 10 a solid, rebuilt 914 gearbox will work fine. |
Mike Bellis |
Jul 6 2010, 07:18 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
All you really need is a 914 type clutch and pressure plate on the 6 flywheel and be done with it. Use the 914 tranny.
SirAndy |
Jul 6 2010, 07:54 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
All you really need is a 914 type clutch and pressure plate on the 6 flywheel and be done with it. Use the 914 tranny. (IMG:style_emoticons/default/agree.gif) I don't consider the 911/901 an upgrade over the 914 transmission ... The stock 901 will do just fine up to 250HP or so, beyond that, go with a 915 box. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
Dr Evil |
Jul 6 2010, 07:57 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yes. You can put the guts (most of them) from one box into another, but you need to preserve the pinion, ring, and intermediate plate indexes. You do need to flip the R&P. There are a few ways to do this:
Good luck - just flip it Better (IMG:style_emoticons/default/wink.gif) - remove the bearings from the diff and swap them from side to side. Check the spacers under the bearings and swap them as well. This will typically keep the ring in the correct plain (IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Jul 6 2010, 07:58 PM
All you really need is a 914 type clutch and pressure plate on the 6 flywheel and be done with it. Use the 914 tranny. Oh ya, if you dont want to go the extra distance for no reason, then just do this and be happy (IMG:style_emoticons/default/wink.gif) |
pcar916 |
Jul 7 2010, 08:31 AM
All you really need is a 914 type clutch and pressure plate on the 6 flywheel and be done with it. Use the 914 tranny. Oh ya, if you dont want to go the extra distance for no reason, then just do this and be happy (IMG:style_emoticons/default/wink.gif) That'd be a 225mm parts, not the 215mm that came with the 914/4's... Unless you have a really small six, the larger clutch will last a lot longer 'cause that's roughly 5.36 square inches more clutch material. More (IMG:style_emoticons/default/driving.gif), less wrenching! |
Lo-Fi Version | Time is now: 9th June 2024 - 09:36 PM |
