Tool to measure valve lift, Need it for valve train geometry |
DNHunt |
Apr 8 2004, 06:09 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Not pretty bot nive and stable.
Attached image(s) |
DNHunt |
Apr 8 2004, 06:11 AM
Dial indicator is parallel with valve stem and should allow me to find full lift.
Dave Attached image(s) |
Mark Henry |
Apr 8 2004, 07:20 AM
I just use my drill press with a rod in it and a mag base on my DI. (IMG:style_emoticons/default/smile.gif)
machina |
Apr 8 2004, 07:24 AM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
mark,
can't really pictue that. Can you describe a little better or maybe a sketch or pic? I'll be tackling this process soon. thanks, dr |
DNHunt |
Apr 8 2004, 08:10 AM
Ya Mark I can't picture it either.
The thing I made can sit on a mocked up engine with only the bales and valve covers removed. I can measure valve lift as the engine is rotated. Dave |
Mark Henry |
Apr 8 2004, 10:16 AM
Put a piece of 3/8" rod in your chuck, tilt the bed or use a jig to make the valve vertical and that will push the valve down. If you tilt the bed you will have to use a piece of angle to use as a stop.
Then put a dial indicator on the retainer using an adjustable magnetic base and measure your coil bind. Often the retainer will hit the guide before coil bind, so I trim just a bit off the top of my guides. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:49 PM |
