no start |
no start |
mipstien |
Jul 10 2010, 04:24 PM
Member Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
Came to tha gas station put in full tank from emtpy and car all of a sudden won't start. Any ideas?
dr914@autoatlanta.com |
Jul 10 2010, 04:31 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
mipstien |
Jul 10 2010, 04:44 PM
i *think* it was flooded. don't know why but thats what it seemed like anyways when it finally did start.
mipstien |
Jul 10 2010, 04:45 PM
but thank you for the fast reply. i was 200 yds from house at the gas station and you replied before i got home haha.
mipstien |
Jul 10 2010, 08:26 PM
ok so there is more to the story now.
i had the cold start valve 'working' and it wouldn't start the first time and i disconnected it because it was the most recent thing i touched. i reconnected it and then it did the same thing later after a 5 minute drive and then disconnected and started up again. i think the cold start valve may be bad? or just not use to that much extra fuel and it's flooding it? |
Tom |
Jul 10 2010, 08:43 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Do a search, this has come up before.
tom |
mipstien |
Jul 10 2010, 09:36 PM
76-914 |
Jul 10 2010, 09:52 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Do a search, this has come up before. tom i did search and found that it isn't supposed to run in such hot weather but that also doesn't indicate why its flooding so easily. why would it flood if it was intended to give it extra gas anyways? odd little booger Because when it is colder the air is more dense. Therefore, you are mixing more air with the gas/CSV when the OAT is cold than if the air was warm. |
Zardozz |
Jul 11 2010, 04:35 PM
Member Group: Members Posts: 107 Joined: 31-March 08 From: Orange County, CA Member No.: 8,874 Region Association: None |
When my car doesn't want to start I hit it with the ether. Works every time (IMG:style_emoticons/default/smile.gif)
avidfanjpl |
Jul 11 2010, 06:36 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I was shown in person a month ago how one cold start injector was stuck open and was flooding a 2.0 with the original unit.
Did not need wire attached to spray fuel, meaning that it failed open. Then he clamped the fuel line to the CSI. The car started instantly. He replaced it next, and never had another problem. But it made me wonder if an electrical fault in the ECU can make the CSI stick open? This was a mechanical failure to open, for sure. Maybe clamp the fuel hose to the CSI and the car will start? J |
mipstien |
Jul 11 2010, 08:01 PM
i appreciate all the input. i believe i figured out what the problem was. kinda feel like i shoulda known but i learn by troubleshooting anyways.
i don't have the temperature sensor hooked up. the one on top of the engine. and the CSI wasn't working before due to a bad ground on it. so between those 2 things when i gave the CSI a good ground it didn't know how hot or cold it was and it just floods the engine. i still don't understand the AAR then cause it is open when i start the car but doesn't make the car rev high to 'warm' it up but it does open and then close fine maybe 5 minutes after the car starts. is the car not supposed to idle high at first when its this hot outside and only when its cold outside? |
Spoke |
Jul 11 2010, 08:14 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
i don't have the temperature sensor hooked up. the one on top of the engine. and the CSI wasn't working before due to a bad ground on it. I'm confused. The temp sensor on the top of the engine IS the ground for the CSI. When the air temp is below freezing, it closes and the one terminal is shorted to the case and this provides the ground to make the CSI work. QUOTE i still don't understand the AAR then cause it is open when i start the car but doesn't make the car rev high to 'warm' it up but it does open and then close fine maybe 5 minutes after the car starts. is the car not supposed to idle high at first when its this hot outside and only when its cold outside? The AAR just provides a little extra air to the intake when the AAR is cold and thus the engine is cold. This helps the engine run smoothly when it is just started and is cold. If the car is hot and turned off, the AAR will share some of the engine heat and when re-started, the AAR may already be closed. The CSI is just for temps below freezing and the AAR is for all temperatures when the engine is cold (ie., room temperature). |
mipstien |
Jul 11 2010, 08:37 PM
heh, well that explains it. my ECU harness isn't bad its just not hooked up (IMG:style_emoticons/default/smile.gif)
glad you explained that makes things crystal clear now. so what are these people saying when the engines rev's to 1700rpm for a couple of minutes? mine doesn't do that it just automatically idles at 900-1000 with no 'warm up' time. that is in the morning after a day of not running so the engine should be about 70F. |
detoxcowboy |
Jul 12 2010, 07:17 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
bump.. aar not funtioning?
mipstien |
Jul 12 2010, 08:43 AM
Lo-Fi Version | Time is now: 1st June 2024 - 05:45 PM |
