OT - 356/912 and type 1 demensional differences |
Scott S |
Jul 13 2010, 12:42 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi all -
I really want to use the below exhaust on a type 1 motor. Other than the obvious flange differences, does anyone know if the motors are demensionally the same in terms of port location? On the front ports, I could use a modified J tube. The rears are a concern. I have asked this question on a couple of other forums, but their traffic is so low that I thought I might try here too. Here is the muffler: http://www.vw-online.co.uk/acatalog/Karman...ng_Parts_7.html Thanks!! Scott S |
Cap'n Krusty |
Jul 13 2010, 01:55 PM
Having worked on both for decades, I'm thinking no. The 356 engine is about the same width as a 36HP VW, the 1500/1600s are considerably wider, I think. The heads are not as wide, meaning the J tube would have to be made shorter, too.
In the end, keep this thought in mind ........ You can do anything you want, my friend, if you have the money .................................... The Cap'n |
charliew |
Jul 13 2010, 01:56 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
Send the mfg a question.
ME733 |
Jul 13 2010, 03:27 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
Exhaust system conversion.....I have experience with the reverse of what you are attempting....V.W. modified E/S to fit 356 engines.....The V.W. engine is approximately 2.25 inches longer and approximately 2 inches wider. This is approximately 2 inches wider at the exhaust port opening, than a 356 engine. Depending on what CAR you put the type 1 engine in you will probably have an INTERFERENCE fit with the 356 axel tubes and rear cylinder exhaust "J" tubes....The added engine length(at the cylinder heads) will necessate a very sharp radus on the new "j" tubes you will need to fabricate...Expanding the width of the exhaust systems shown is simple fabrication.
Lo-Fi Version | Time is now: 9th June 2024 - 06:38 AM |
