Possible e-brake options |
moparrob |
Jul 20 2010, 08:39 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
The 914 I bought does not have a hand brake installed. The PO took it out and had the guts re- cad plated but never put it back together or installed it. Good news is I do have the cables, though.
So I installed some 996 seats and I am concerned the original e-brake handle will be jammed into the area next to the new seats (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1279679975.1.jpg) The question I have is: Has anyone tried using an after market handle like the Lokars pictured? Perhaps in the area between the two seats on a custom fabbed mount? (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1279679977.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1279679977.3.jpg) Any thoughts on the subject? As always - appreciated in advance. Rob |
okieflyr |
Jul 20 2010, 09:00 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I know that a couple of people have converted or started too. I don't remember the outcomes, but the search engine may help. I kinda like your seats by the way!
Eric_Shea |
Jul 20 2010, 09:04 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Some GT's had a 911 handbrake assembly fab'd in them.
Google "Armando, 914-6/GT" and check out Armando's site for all of the fab and install pictures from the factory cars. Also, check the Jeff Hale resurection thread herein (can't remember the exact name of the thread) Jeff is installing a center mount handbrake. |
charliew |
Jul 20 2010, 10:55 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
911/944 any center emergency brake handle with the cables that come with them should work I would think. I have a leather covered 944 one with cables I am going to use if I can't fit a toyota foot pedal one in.
jaxdream |
Jul 21 2010, 06:53 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Personaly , I plan on using a 964 E-brake handle between the seats ,make a custom center console to surround it, lower profile , readily available , easy to mount , can be had with a black leather cover . I was going to use a Boxster , but changed my mind when I looked at the 964's , they where just nice and low , and wouldn't sit up as high as the Boxster. your call as to what you end up with. Just some other ideas. I see you went with what appears to be 924 / 944 door pulls and pockets , look great with the padded pleats on the door panels.
Good luck ..... Jack / Jaxdream |
Mike Bellis |
Jul 21 2010, 09:48 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm running a hydraulic brake between the seats taped into the rear line. My car has 930 brakes and the PO gutted the hat. So I had no factory e-brake parts to start with.
jaxdream |
Jul 21 2010, 10:25 AM
I'm running a hydraulic brake between the seats taped into the rear line. My car has 930 brakes and the PO gutted the hat. So I had no factory e-brake parts to start with. That does work , but IIRC state laws (Your's may differ ) require that the hand brake / e-brake/ parking brake setup to be mechanical , seperate from the hydraulic system .YMMV... Jack / Jaxdream |
Mike Bellis |
Jul 21 2010, 11:12 AM
I'm running a hydraulic brake between the seats taped into the rear line. My car has 930 brakes and the PO gutted the hat. So I had no factory e-brake parts to start with. That does work , but IIRC state laws (Your's may differ ) require that the hand brake / e-brake/ parking brake setup to be mechanical , seperate from the hydraulic system .YMMV... Jack / Jaxdream It may not be DOT leagal. California does not have inspections. The unit I have has an internal check valve that stops the fluid going forward when pulled and latched. It's made for the drifting crowd but it works good for me. I use it to park but I have tested it and it will lock the rear brakes up. It was cheaper than trying to find all the 930 brake parts and rig to the 914 handle that I didn't have. |
moparrob |
Jul 22 2010, 11:36 PM
Thanks for the info guys.
Eric - I couldn't find anything on Jeff Hale. I'm not impressed with the search engine, though... I guess for now I'll try to locate a 964 handle and fab up some mounts. I hope I don't need to make new cables. but we shall see.... |
charliew |
Jul 22 2010, 11:40 PM
944 cables go two into one. check them out also. They are also a source for the angle pull type of spreader that is used on the 914 with 911 brakes. It's the same spreader thats on bmws also.
strawman |
Jul 23 2010, 12:27 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
944 cables go two into one. check them out also. They are also a source for the angle pull type of spreader that is used on the 914 with 911 brakes. It's the same spreader thats on bmws also. I picked up a set of 944 "spreaders" from a local Pick-n-Pull and was honestly underwhelmed, so I went with 911 parts for my parking brake setup that I've built into my project. True, it pulls only from one side, but I've followed the lead of others that have used the same concept. Full disclosure: my car is done yet, but I don't remember seeing a completed 944 spreader-type setup used in real-world use... |
Lo-Fi Version | Time is now: 10th June 2024 - 12:24 PM |
