muncokiho |
Newbie ![]() Group: Members Posts: 10 Joined: 14-July 10 From: Houston, Tx Member No.: 11,937 Region Association: None ![]() |
I know there are many options but just need an approx. cost of a 1.8 rebuild stock possibly with bigger p&c if possible. Should be a strait forward rebuild as the engine is low mile but sat so long the pistons are froze. Thanks,cole
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I know there are many options but just need an approx. cost of a 1.8 rebuild stock possibly with bigger p&c if possible. Should be a strait forward rebuild as the engine is low mile but sat so long the pistons are froze. Thanks,cole A long sitting car with frozen cylinders may not be lost.... put the car in 5th and push, you'll likely hear a large pop.... |
EdwardBlume |
Once you have the engine unfrozen... its time to replace all the fuel lines and potentially the fuel injectors...
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
And a full rebuild is 3500-5K IMO
rallysport70 |
Member ![]() ![]() Group: Members Posts: 64 Joined: 1-May 09 From: Albany, NY Member No.: 10,321 Region Association: North East States ![]() |
I am in the process of having my 1.8L professionally rebuilt w/2056cc pistons/cylinders, upgraded cam for $3600 cash. I expect the cost could rise slightly if any minor surprises are found. I;m keeping the original fuel injection. I'm also in no rush as I'm doing the hell hole repair, so the builder is just using it as fill in work when he's not busy.
Lo-Fi Version | Time is now: 10th June 2024 - 06:56 AM |
