Help me price my setup, Thinking of selling my V8 conversion stuff |
Mike Bellis |
Jul 24 2010, 05:06 PM
I'm almost ready to do another engine swap. Not exactly sure what engine yet. I need to get rid of my V8 conversion stuff first. Help me figure out what it's worth.
I would like to sell the engine tranny as a package. Just install fuel pump and go... 283 Chevy Mild cam roller rockers gear drive 12 quart road race oil pan Corvette Crossfire fuel injection 901 tranny regeared with taller 5th 1st gear not locked out Renegade adapter, flywheel, clutch, pressure plate. enegade engine mount. It will come with exhaust. may not be the one pictured. |
matthepcat |
Jul 24 2010, 05:22 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
This set up runs great.
I would say the value is higher if you can find a buyer while it is still installed in your car. That way they can see that it runs and shifts perfect. Engine+fuel injection & renegade set-up: $2,500-2,800 Transmission/clutch assembly: $2k After seeing your fuel injection, and dealing with vacuum problems on my conversion all last night, I am inspired to run TBI. Good Luck, Matt |
Andyrew |
Jul 24 2010, 05:41 PM
Engine 2k
Conversion (I assume minus radiator setup) 4-500 Trani I dont see it selling for more than 1k. Good trani's go for 4-500, since yours is rebuilt w/ the 5th gear I'd say 1k. Im in the same boat as you know, im just behind schedule. Whats your engine/trani combo? Subaru? Audi? ?? |
Lennies914 |
Jul 24 2010, 07:10 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
(IMG:style_emoticons/default/idea.gif) Do I see a rotory/auto set-up in your future? (IMG:style_emoticons/default/confused24.gif)
Mike Bellis |
Jul 24 2010, 07:17 PM
Engine 2k Conversion (I assume minus radiator setup) 4-500 Trani I dont see it selling for more than 1k. Good trani's go for 4-500, since yours is rebuilt w/ the 5th gear I'd say 1k. Im in the same boat as you know, im just behind schedule. Whats your engine/trani combo? Subaru? Audi? ?? I am open to options. The only thing for sure... There will be a turbo. Audi Turbo W/audi transxale Subi Turbo w/ subi transaxle Rotary turbo w/ ? transaxle The goal will be 300-350 HP |
underthetire |
Jul 25 2010, 03:04 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Hum, sell the small block and put a turbo 4.3 with aluminum heads in it. Most of your stuff would swap right over (IMG:style_emoticons/default/biggrin.gif)
Andyrew |
Jul 29 2010, 11:59 AM
300-350hp, I'd think the subaru turbo would be your cheapest option as you should be able to get that power from the factory turbo on an STI engine.
The Audi engine is limited to 350-400hp on the stock rods, and needs a bigger turbo to get over 250hp. The VW passat 1.8t FWD manual trani or the Audi a4 1.8t FWD manual trani is the bolt in setup you'd be looking for.. I would HIGHLY recoomend a 16lb steel flywheel if you go with a Audi setup. Even lighter might not be bad, but the stock flywheel is HEAVY. Do you plan to retain the A/C or climate control? How about the dash? (Like I was mentioning on my conversion) |
Lo-Fi Version | Time is now: 1st June 2024 - 05:12 PM |
