Tuna can instructions? |
cgnj |
Jul 28 2010, 05:44 AM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
So I'm boxing up parts and found a NIB tuna can with no instuctions. Can anyone give me the condensed installation instructions?
Thanks, Carlos |
VaccaRabite |
Jul 28 2010, 05:53 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Pretty easy...
Remove the sump and screen. Attach the tuna can and torque it down lightly. Too much and you break the case stud. The tube with the cut outs attaches with the cut outs facing towards the bottom of the can (facing towards the ground). Zach |
cgnj |
Jul 28 2010, 06:10 AM
Pretty easy... Remove the sump and screen. Attach the tuna can and torque it down lightly. Too much and you break the case stud. The tube with the cut outs attaches with the cut outs facing towards the bottom of the can (facing towards the ground). Zach Crush washer and O ring go where? Carlos |
VaccaRabite |
Jul 28 2010, 06:35 AM
IIRC the O-ring seals the aluminum tube to the case.
The crush ring acts exactly like it does on the oil drain bolt. Put it between the attaching bolt and the outside of the tuna can. Zach |
cgnj |
Jul 28 2010, 07:14 AM
Thanks Zach. I fixed all the old oil leaks, time to add a new one.
Carlos |
tradisrad |
Jul 28 2010, 07:37 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I dont see the gasket that goes between the "can" and the engine in your picture, you will need that.
Also the oil screen can be modified (trimmed) to fit inside the can. |
VaccaRabite |
Jul 28 2010, 07:55 AM
I dont see the gasket that goes between the "can" and the engine in your picture, you will need that. Also the oil screen can be modified (trimmed) to fit inside the can. I agree. You do need the thick paper gasket, just like the one on the sump cover. Call any of the normal places and you can probably get one for under a buck. You might be able to reuse the one from your sump, but that is poor form and you might get a leak that way. I'd not bother with the screen though. Any chunks in your case big enough to get stopped by the screen and your engine has already bit the dust. Zach |
type2man |
Jul 28 2010, 08:17 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I dont see the gasket that goes between the "can" and the engine in your picture, you will need that. Also the oil screen can be modified (trimmed) to fit inside the can. I agree. You do need the thick paper gasket, just like the one on the sump cover. Call any of the normal places and you can probably get one for under a buck. You might be able to reuse the one from your sump, but that is poor form and you might get a leak that way. I'd not bother with the screen though. Any chunks in your case big enough to get stopped by the screen and your engine has already bit the dust. Zach I've seen a rocker arm clip break off and get sucked in through the suction tube and break the oil pump stud off and seize the engine in a matter of seconds.... put the pool screen back on LOL!!! |
914werke |
Jul 28 2010, 10:38 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Anyone have a pic of the screen mod?
Lo-Fi Version | Time is now: 8th June 2024 - 11:16 AM |
