Windsheild Washer Electric Motor, Where to connect |
2-OH! |
Apr 12 2004, 12:55 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
I am converting 2.0 to electric windshield washer pump...Can any of you six cylinder guys tell me which terminal on the fuse block the pump drives off of and what size fuse...
2-OH! |
ArtechnikA |
Apr 12 2004, 01:05 PM
i posted the fuse assignments from the owners' manual in This Thread but it doesn't list washer pump. if i had to guess, it'd be #8.
i can check my wiring diagram tonight if somebody hasn't beat me to it... |
SirAndy |
Apr 12 2004, 01:32 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
don't remember which one i used. just picked one that had 12V after the key was turned. it's not like i need the pump much here in CA (IMG:style_emoticons/default/wink.gif)
Andy |
SirAndy |
Apr 12 2004, 01:35 PM
oh, and btw. it'll help alot if you drill a small hole in the black plastic cap on your washer bottle. right now, it has a valve in it that needs pressure (from the spare tire) to open. without that pressure, the sucking of the electrical pump is not enough to open it and you won't get much water sucked out of the bottle. with the small hole, you get plenty of air into the bottle and it'll work much better ...
Andy |
Martin Baker |
Apr 13 2004, 12:22 AM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
There is an excellent article on how to do this on PP Board. Its step by step. Do you have the 924 switch? It is wired for the pump.
Lo-Fi Version | Time is now: 10th June 2024 - 01:35 AM |
